(Question) How to increase Acceleration/Torque?
TIA
TIA
Oh and about the FI section, yeah that's the easiest, but i'm specifically going for like acceleration/torque. FI seems to easy.
PS: For those of you that didn't know: In 1946
Gyro-Matic semiautomatic transmission became optional. This was an important sales point at a time when people were tiring of manual shifting. Fluid Drive with Gyro-Matic was a complex solution to a simple problem, combining a conventional clutch with a fluid coupling that multiplied torque like a torque converter; electrical shift circuits added to what one writer called a "full range of potential transmission trouble." The coupling performed the usual flywheel functions of storing energy, smoothing power impulses, and meshing the ring gear with the starter pinion.
Lacking a clutch-plate contact, a clutch was mounted in tandem. The fluid coupling was a drum filled with low-viscosity mineral oil. Running the engine rotated a set of vanes attached to the inner face that threw oil outward onto a facing runner with another set of vanes. The oil turned the runner to provide a smooth flow of power while avoiding any metal-to-metal contact.
Fluid Drive had two gear positions: Low, governing first and second gears, High for third and fourth. Low was mainly for fast starts or towing. In most other driving you simply shifted into High and pressed the accelerator, then let up at 14 mph, when a "thump" announced the shift from third to fourth. Stops and starts required no clutching or shifting, hence Chrysler's claim that Fluid Drive Gyro-Matic eliminated 95 percent of all shift motions. The clutch was there, but was used only to change between Low and High or to back up.
But seriously congratulations on the Vette and the first thing I bought was a set of Borla Stingers then the list continued to grow and I don't think it will ever stop.
There, Fixed it.
TIA
, Procharger 8psi and 3.90 diff, FAST 90/90, Cam, good clutch, sticky tires, a little meth, I could go on and on
