reprogram fob
Jan 20, 2008 | 11:25 PM
reprogram fob
can i reprogram my fob and if so how? do i have to have chevy do it?.thanks
Jan 20, 2008 | 11:28 PM
It's easy... You do it yourself.
1) Turn ignition on
2) Turn radio off
3) Press Driver Information Center (DIC) RESET button ( 6 )
4) Press OPTIONS button on the DIC until display is blank ( 4 )
5) Press and hold RESET button for 3 seconds ( 6 )
6) Press OPTIONS button until FOB TRAINING is displayed ( 4 )
7) Press RESET button to begin programming sequence. ( 6 )
8) Simultaneously press and hold LOCK and UNLOCK ( A & B )
buttons on first remote for 13 seconds until message
appears stating programming is complete. The computer
will ask to program second FOB. If you don't have a second
FOB follow on to step 9.
9) Turn ignition off and remove key for ignition.
10) Test remote or remotes
Jan 20, 2008 | 11:57 PM
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Quote:
Originally Posted by
damilleniumboy
1) Turn ignition on
2) Turn radio off
Right on the money right out of the drivers hand book!
If you have your drivers hand book it will have it in there too!
Thanks,Matt
Jan 21, 2008 | 12:03 AM
Jan 21, 2008 | 12:24 AM
You can also just try pressing the lock and unlock buttons at the same time until the horn honks.
Jan 21, 2008 | 12:28 AM
JDs00PewterCoupe
Jan 21, 2008 | 08:52 PM
Does this procedure has to be done if the battery on the FOB is replaced? mine is going kaplooey right now so im in need of a new battery.
Jan 21, 2008 | 08:55 PM
PR'Corvette
Yes I believe so.
Jan 21, 2008 | 09:06 PM
All Men Die, but Few LIVE
Cruise-In IX Veteran
St. Jude Donor '08-'09
It only takes a few seconds to program the FOB's, even if you are doing all 3(3 is the max # of FOB's allowed). There are lots of little 'secret' programs in there...like an 'Idle relearn', (if you have done any intake mods or have a hesitation problem on take off..) Someone sent me a list of all the programming things you can do in there and it was something like 30 different ones, just by pushing the right butons in the right order, at the right time....Someone smarter than me programmed all those commands in there!
~Maverick
Jan 21, 2008 | 09:15 PM
Sep 5, 2008 | 11:42 AM
Nov 23, 2008 | 02:29 PM
dndrsn
The links are not working anymore.
Nov 23, 2008 | 02:31 PM
JDs00PewterCoupe
Wouldn't a criminal be able then to make their fob work to get in your car?
Nov 23, 2008 | 03:24 PM
I believe pushing the lock and unlock at the same time will just re-sync the fob to what's already programmed in the car. This will work a lot of the time without having to go through the complete reprogramming. So a criminal wouldn't be able to make their fob work this way, unless they're awful lucky.
Nov 23, 2008 | 03:42 PM
FAAASTJEDI2000
Re-syncing will only work on a FOB that's been matched to your Vette.
Nov 24, 2008 | 08:11 AM
~Maverick
~Maverick
Wanna share those 30 programs???? Please????
