Battery Charge
Old Jan 27, 2008 | 08:23 PM
LAHeat's Avatar
LAHeat
LA Heat
Default Battery Charge
I will be storing my car for approximately (3) months. Is there a device that will keep my battery charged during that time? If I don't have to, I would rather not disconnect the battery - unless I have to.
Old Jan 27, 2008 | 08:26 PM
thetaxman's Avatar
thetaxman
battery tender, 50 bucks
Old Jan 27, 2008 | 08:33 PM
peter pan's Avatar
peter pan
Life Time NCM #2196
I use one on my Vette to keep my red top working fine as they do not like being drained
Old Jan 27, 2008 | 08:35 PM
steve8's Avatar
steve8
If your question is serious, a battery tender.
Old Jan 27, 2008 | 08:36 PM
renegad44's Avatar
renegad44
From: This is not a Song, It's an Outburst: Or, The Establishment Blues; Sixto Diaz Rodriguez
Whenever she's sitting at home, she's plugged in.
Big-Red's Avatar
Big-Red
St. Jude Donor '06-'07-'08-'09-'10,'13-'14
$15.00 and works great!!
http://www.lectriclimited.com/battery-butler.htm
Old Jan 27, 2008 | 08:37 PM
04cad's Avatar
04cad
St. Jude Donor '07-'08
Do a CF search for battery tender or battery minder or battery charger. Harbor Freight had a big sale on theirs recently and there is even one that is solar powered. Good luck!
Old Jan 27, 2008 | 08:45 PM
WetteVette's Avatar
WetteVette
I'd go with the Battery Tender Plus.
Been using them for years. No problems. Work great.
When not in use, the 'Vette and Harley are always hooked up to the Battery Tender.
Old Jan 27, 2008 | 09:29 PM
LAHeat's Avatar
LAHeat
LA Heat
Thank You ALL very much - that is exactly what I needed to know and will purchase! (battery tender)
THANKS AGAIN!
Old Jan 27, 2008 | 10:59 PM
I use a battery tender plus on my car - works perfect. Cost was around $60 tax included.
Old Jan 27, 2008 | 11:05 PM
Rans03's Avatar
Rans03
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08
A Battery Tender Plus can be had on fleabay for just over $40, great unit.
Old Jan 28, 2008 | 01:42 AM
DeeGee's Avatar
DeeGee
And once you're back on the road you can keep the battery topped off. No danger of a dead batetry once you have a tender.
Old Jan 28, 2008 | 09:07 AM
WvCorvette's Avatar
WvCorvette
This is the 3rd winter I had a battery tender on mine!!
Old Jan 28, 2008 | 09:26 AM
Bills03Coupe's Avatar
Bills03Coupe
I have the CTEK Multi 3300 and it works great! When my car sits, I connect it to the top terminals on my Exide Orbital. Got mine from Chip @ CCA
Old Jan 28, 2008 | 09:35 PM
mud flap's Avatar
mud flap
Ok I'll bite... whats the difference between a battery tender and a battery tender PLUS? The reason why Im asking is I just went out to start my 01 for the first time in a week and the flippin' battery is dead.
Beings the battery's dead can I still hook up the battery tender or do I have to pull the battery and have it charged in order to get my car started? FWIW that battery's only a couple of years old
TIA
Mud
Old Jan 28, 2008 | 11:37 PM
ZO6 Lee's Avatar
ZO6 Lee
St. Jude Donor '08-'09-'10
I have charged my battery with my charger when it was totally flat without disconnecting. Took a while but it works. be patient.
Old Jan 29, 2008 | 02:15 PM
LMH4C5's Avatar
LMH4C5
National Champs Gators 4 St. Jude '09
To Battery Charge
Old Jan 29, 2008 | 03:44 PM
Mrdrnac's Avatar
Mrdrnac
TIA
Mud
The battery tender is smaller and charges at 800ma
The battery Tender Plus is larger and charges at 1.25amps
Also FYI, there are two versions of the Battery Tender Plus one for regular batteries and one for Gell Cell batteries only.
Old Jan 29, 2008 | 03:45 PM
msraway's Avatar
msraway
Old Jan 29, 2008 | 04:24 PM
hotwheels57's Avatar
hotwheels57
People tend to use the words "battery tender" in generic terms, referring to any maintenance type charger.**
The BATTERY TENDER is a specific model manufactured by DELTRAN CORPORATION. They sell a BATTERY TENDER PLUS (@ 1.25 amp) and a BATTERY TENDER JR (@ .75 amp) and even units for charging multiple batteries at once. They have a wide range of float maintenance type chargers with warranties as long as 10 years. They're reverse polarity circuit protected and won't harm your sensitive C5/Z06 electronics. You can find them at most motorcycle shops or PEPBOYS.
The CTEK is the next generation of maintenance charger, referred to as a pulse charger. It's somewhat similar to a BATTERY TENDER, but has many new higher tech features. It's been very popular in Europe.
**Don't confuse a BATTERY TENDER with BATTERY MANAGER, or BATTERY MINDER and other off shore products available through WALMART or HARBOR FREIGHT or similar sources.
