Camber adjustment
Old Feb 2, 2008 | 03:04 PM
KBRVETTE93's Avatar
KBRVETTE93
Default Camber adjustment
Is there a relatively simple to adjust the camber in a C-5 using Jack stands?
Old Feb 2, 2008 | 04:55 PM
thetaxman's Avatar
thetaxman
when you change the camber , toe will be affected too.
you can do it , but you'll need to adjust toe.
all you do to adjust camber is move the eccentrics on the lower control arm
SOME MORE INFO
http://forums.corvetteforum.com/show...36&postcount=8
Old Feb 2, 2008 | 05:12 PM
AU N EGL's Avatar
AU N EGL
Look on David Farmers web site
http://www.davidfarmerstuff.com/
15 years as a professional racer
Lots of good info.
I do my own alignments.
To Camber adjustment
