Jack stands location
Old Feb 4, 2008 | 03:08 PM
TEXASCOUPE's Avatar
TEXASCOUPE
Default Jack stands location
Going to get ready for an upcoming car show and need to start cleaning. Would like to take all 4 wheels off to re-paint the calipers and clean the under side. I've never used jack stands on all 4 sides and was wondering where they should be positioned to protect the car and me. Anyone have any pics to help me out?
Old Feb 4, 2008 | 03:13 PM
Itallian33's Avatar
Itallian33
We replaced the clutch on a friends car and this is where we put them. Used Lifting pucks to do it
Old Feb 4, 2008 | 03:17 PM
Vega$Vette's Avatar
Vega$Vette
1 each under the front A-Frames and 2 under the rear cross member.
Old Feb 4, 2008 | 03:21 PM
DeeGee's Avatar
DeeGee
Here ya go. These are the jacking points. get the jack stands outboard and you'll be fine
Old Feb 4, 2008 | 03:24 PM
AU N EGL's Avatar
AU N EGL
Old Feb 4, 2008 | 03:25 PM
Billysc5's Avatar
Billysc5
Only one beer must have been an easy job!!
Old Feb 4, 2008 | 03:39 PM
TEXASCOUPE's Avatar
TEXASCOUPE
Mine might be a 6 pack or two! Thanks guys for the quick response.
Old Feb 4, 2008 | 03:56 PM
Itallian33's Avatar
Itallian33
only one at a time....there isn't much room to swing 12oz while you are crawling around under there
Old Feb 4, 2008 | 04:15 PM
TEXASCOUPE's Avatar
TEXASCOUPE
Good point!
Old Feb 4, 2008 | 05:07 PM
Jistari's Avatar
Jistari
Havent put it up on four yet, and have barely enough room to walk past on the drivers side in my garage (I guess about 18 inches), so Im not looking foward to trying
What I was thinking to do was :
Use the outboard jacking location (which is the only place the jack will fit under the car anyway) to lift one side high enough to get a jackstand under the closest midline point (so in the diagram above, jack it up from the LF (one o'clock position) and get a jackstand under the two o'clock position. Then let the jack down, move it out of the way and set a jack stand under the one o'clock position. Then do the other side. Then I may still be able to raise the rear from the center rear position.
Anyone who has done this, and wants to chime in with the "you're gonna kill yourself if you do it that way", I assure you, I wont take offense
That about how its done?
Old Feb 4, 2008 | 05:16 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Nice pic, thanks
Old Feb 4, 2008 | 05:21 PM
Itallian33's Avatar
Itallian33
Doing that you will end up the car tilting pretty far to one side. You really want to raise the front of the car first, place the foward two jackstands then raise the back two stands. I have to drive up on a custom ramp made from 2X10 to get it high enough to get the jack under her. Hope this helps.
Old Feb 4, 2008 | 05:23 PM
04 commemorative's Avatar
04 commemorative
St. Jude Donor '17
Get the pucks from BMW...they snap in and stay in!
Old Feb 4, 2008 | 06:05 PM
Vega$Vette's Avatar
Vega$Vette
So if you jack it up using your floor jack with the jacking pucks as shown in the diagram...How to you get the jack stands under the same location?
Old Feb 4, 2008 | 06:41 PM
Jistari's Avatar
Jistari
exactly
I knew guys used ramps so that they could get to the center locations, was trying to avoid that just due to no place to store anything else in my garage as it is :-)
I hear ya Italian33, if I do it, Ill make sure Im careful about the uneven periods.
Old Feb 4, 2008 | 08:09 PM
jss812's Avatar
jss812
Here's a suggestion I got from a good friend.
You want to jack the front first. Use the skid bars to jack the car high enough to get the jack past the air dam. I usually use a 2x4 across both bars and you want to make sure you don't try to jack it up any higher than what's needed to get the jack past the air dam. One more time - don't jack it up any higher than necessary to get the jack past the air dam. Then just block it up there, put the jack under the cross member, jack it up high enough to get your jackstands where you want them. Then go to the back and jack it up from the cross member back there. Place your rear jackstands. Done.
The skid bars are fairly stong (how many of us have skidded up on curbing or similar?) but use great care. You don't want to raise the front tires or anything like that. Just high enough to get the jack past the air dam.
To Jack stands location
