Leaking battery solution?
Feb 4, 2008 | 10:29 PM
I've learned a lot from you guys and am familiar with the leaking battery acid on the computer issue. I've also been around boats for a long time and a lot of small curisers have plastic battery boxes to keep the battery safe & dry. What do you think about cutting a plastic boat battery box to house a battery in a C5?
Feb 5, 2008 | 01:48 AM
Sounds like a great idea.
Most members that have had issues normally fit a battery mat under the battery. I went the high $$ route and fitted an Optima Yellow Top
Feb 5, 2008 | 02:22 AM
it will work but the hold down may be a problem
I'd just get a gel cell or an Optima
Feb 5, 2008 | 02:36 AM
Quote:
Originally Posted by
DeeGee
Most members that have had issues normally fit a battery mat under the battery. I went the high 44 route and fitted an Optima Yellow Top
Feb 5, 2008 | 02:38 AM
DeeGee
most do not waste time fixing a symptom
most fix the root cause of the problem
Feb 5, 2008 | 02:56 AM
A couple of bungie cords should fasten it in there pretty good.
Just sign me Bubba.
Feb 5, 2008 | 04:03 AM
thetaxman
Feb 5, 2008 | 05:17 AM
St. Jude Donor '07
thetaxman
He's right, get ANYTHING except an AC DELCO side post battery. The '03 - '04 models had top post batteries, they are OK. Many members just replaced their batteries from Autozone, Sears, Costco, and haven't had any further problems. If you have an original AC Delco replace it!
John
Feb 5, 2008 | 07:31 AM
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13
A battery mat is cheap insurance
Feb 5, 2008 | 10:13 AM
Yeah I've already got on Optima red top in there and was going to put a mat, but I though a box might be another option.
Feb 5, 2008 | 10:27 AM
coldwater-echelon
The red top won't leak so you will just be wasting time and money on a problem that's not there.
Just stick with Optima, problem solved.
Feb 5, 2008 | 03:17 PM
thetaxman
Read up on the history. I posted this thread 18 months ago
http://forums.corvetteforum.com/show....php?t=1469503
Feb 5, 2008 | 04:39 PM
coldwater-echelon
a member has mats in the for sale section $4.85 shipped........
