Holy Crap
Old Feb 11, 2008 | 10:39 PM
geterdone's Avatar
geterdone
Default Holy Crap
Is it hard to pull off the stock cat back exhaust system or is it just me, I have been trying to pull the passanger side muffler off for two hours now and I give up. I will take it to my friends lift tommorow, I am tired of messing with it.
Old Feb 11, 2008 | 10:48 PM
2vettes2go's Avatar
2vettes2go
you have to jack it up real high to get enough ground clearance to get it off. get a set of jack stands and lift it up , place stands at rear support area then place boards under jack till you get it up enough to clear. passenger side is the hard one....but it will come off.
Old Feb 11, 2008 | 11:03 PM
Rupert's Avatar
Rupert
yea you got to get the tail end of the car way up there. When I did mine, it was so high the front of the car was on the ground. I hear it is really tough on automatics. One piece of advice disconnect the sway bar mounting brackets, and lower the sway bar, that also gives you some more wiggle room.
Old Feb 11, 2008 | 11:41 PM
jrose7004's Avatar
jrose7004
With a lift it's absolutely no big deal!
Old Feb 11, 2008 | 11:44 PM
geterdone's Avatar
geterdone
I lifted it as high as I could go with the jack I had, any higher than I would of started to feel uncomfortable. Go to the lift tommorow.
Old Feb 11, 2008 | 11:49 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
Drop the swaybar if you haven't already done so.
Old Feb 12, 2008 | 12:08 AM
kerryt1's Avatar
kerryt1
sawzall is your friend (unless you're trying to save it).
Old Feb 12, 2008 | 01:25 AM
tellefan's Avatar
tellefan
It also helps out to remove the passanger side gas tank heat shield. David
Old Feb 12, 2008 | 06:18 AM
Good move going to a lift. Will make it much easier. Good luck getting the swap made.
Old Feb 12, 2008 | 06:22 AM
vetter79's Avatar
vetter79
If you're going to replace it, go the sawzall route - hell of a lot easier!
Old Feb 12, 2008 | 06:29 AM
chuck1026's Avatar
chuck1026
Cruise-In II Veteran
If you want to keep the OEM stuff in tact for future use (going back to stock if it ever becomes a "true classic" or whatever)... the rear has to be about 3 feet off the ground (definitely no less).
Old Feb 12, 2008 | 06:54 AM
csexton's Avatar
csexton
Good luck and a lift will make it much easier
Chuck
Old Feb 12, 2008 | 07:04 AM
nwdanner's Avatar
nwdanner
I took mine off without cutting, but it wasn't for the feint of heart. I lifted the car using (4) 2"x6" boards and a 3-ton floor jack. To be safe (can't skimp here), I screwed the boards together and notched the top and bottom boards to interlock with the rear cross member and the head of the jack. After blocking the front wheels, I unbolted the exhaust, jacked the car, and easily removed each side intact. Hardest part was fabricating the blocks.
Old Feb 12, 2008 | 07:54 AM
Tom/99's Avatar
Tom/99
You need the bottom of the rear bumper up at least 30 inches high. After that, it's real easy.
Old Feb 12, 2008 | 09:05 AM
divitasbluepitbulls's Avatar
divitasbluepitbulls
Dropping the passenger side sway bar hook up is a MUST!! You can get it off without a lift. But, a lift would be an asset. Good luck
Old Feb 12, 2008 | 10:29 AM
Red3644's Avatar
Red3644
10 minutes with a lift. If you have an auto trans, you have to drop the gas tank shield and shift the tank over just a bit. Remove the center
sway bar mounts and swing the bar down. There shouldn't be a problem after that.
To Holy Crap
