Dangling Air Dam
Old Feb 29, 2008 | 12:36 PM
hayman's Avatar
hayman
Default Dangling Air Dam
What holds the center air dam piece to the frame other then the wire lanyard that is allowing it to hang to the car now?
Bill
Old Feb 29, 2008 | 12:38 PM
02MillenniumVette's Avatar
02MillenniumVette
If I remember correctly there are some torque screws that hold it in place. Its been awhile since Ive taken mine off. Im sure someone else will chime in and correct me if Im wrong.
Old Feb 29, 2008 | 12:44 PM
VERTC5's Avatar
VERTC5
Bill
There is an entire spring loaded support that the center air dam connects to. If you simply have a wire lanyard, I would say someone "jury rigged" it there.
Old Mar 1, 2008 | 10:55 AM
hayman's Avatar
hayman
Ttt
Old Mar 1, 2008 | 10:58 AM
AlisonC5's Avatar
AlisonC5
It has a bolt on each end, and 2 near the center with aluminum brackets that "hook" into the back of the air damn. least that's what my 98 has.
Andy
Old Mar 1, 2008 | 11:02 AM
mqqn's Avatar
mqqn
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
St. Jude Donor '03-'04-'05-'06-'07-'11
Hi Hayman -
The center portion of the air deflector is held in place with bolts on each side.
The deflector has a relatively flimsy metal frame with stamped-in brackets that are (apparently) designed to bend when the deflector comes in contact with debris. The rubber lip is hinged to allow it to bend back and then return if the lip hits debris, but I found out about the brackets when I hit something more substantial than the hinge-arrangement allowed for lol.
If the rubber lip on the deflector is dangling by what you describe as a wire, I suspect that the hinges have become separated from the frame/bracket.
While it may be possible to rig something up to fix it, I would submit that you can buy a new center section (frame and all) for ~$55.00 USD.
best regards -
mqqn
Old Mar 1, 2008 | 02:21 PM
Johnny Hardcore's Avatar
Johnny Hardcore
I used black zip ties on mine, because I replaced it twice, and the third one which is now on the car is wrecked again. I just zip tied it up and have had zero problems since.
Old Mar 1, 2008 | 04:33 PM
hayman's Avatar
hayman
Originally Posted by mqqn
Hi Hayman -
best regards -
mqqn
Is this a complete kit with all the hardwear? It would seem everything is gone from mine. Where do I get this kit? Steelership?
Might give this a try in the mean time. Thanks
Old Mar 1, 2008 | 04:45 PM
jss812's Avatar
jss812
Bill
Sounds like you have a missing spring.
Here's the back side of a new one.
Old Mar 1, 2008 | 11:58 PM
2000lambovette's Avatar
2000lambovette
I made mine fall off after a samll (forced off the raod by big rig) accident. The small bracket that hold it on has springs that let it flap. Well I broke mine & rebuilt it with 1 1/2 inch square tubing and 4 small but storng coil spring with a bolt running through them. It works better than before and the new brace is much stronger and it only cost around $7.00 for all the parts.
Old Mar 2, 2008 | 04:37 PM
To Dangling Air Dam
