Odd problem at high speed
Old Mar 8, 2008 | 06:30 PM
fcoppola's Avatar
fcoppola
Default Odd problem at high speed
I have the strangest problem. I have experienced this 3 times, although I have only driven speeds this high 3 times. It seems, once I hit 130mph my dashboard lights up. I get ABS failure, traction control failure, active suspension failure, all the lights on the dash illuminate indicating major problems with the car. There is no noticable performance hit, and everything seems fine. The lights stay on until the car is powered off. Upon restarting the car, they are gone as if nothing happened.
Has anyone seen of heard of this before?
Old Mar 8, 2008 | 07:12 PM
RonJ's Avatar
RonJ
That's the good Lord telling you to slow down .....
RonJ ...
Old Mar 8, 2008 | 07:19 PM
jacks996's Avatar
jacks996
Jacks996
Cruise-In VIII Veteran
Make sure you mention you are on the track or the (keep it on the track police) will lock your thread
What codes does it show?
Old Mar 8, 2008 | 07:37 PM
Nope, never heard of that happening before. Are any codes being thrown?
Old Mar 8, 2008 | 07:39 PM
C5R USA's Avatar
C5R USA
From: Ideals are peaceful...History is violent...St.Charles, MO.
C5 of Year Winner (appearance mods) 2019
St. Jude Donor '08-'09-'12 thru'22
First time I've heard anything like that...interesting.
Old Mar 8, 2008 | 07:52 PM
WKMCD's Avatar
WKMCD
What are your wheel and tire sizes?
Old Mar 8, 2008 | 08:13 PM
Junkman2008's Avatar
Junkman2008
RonJ ...
Old Mar 8, 2008 | 11:16 PM
fcoppola's Avatar
fcoppola
Default hey
I guess I could go to autozone and see if there are any codes in the history. Upon restarting the car like I mentioned, all error lights/warnings are gone. I just assumed I couldnt get a code off it. Lets just say I have never had a code reader available when the lights did come on.
Members in the club I am in have topped 160 on a regular basis at the track and have never had problems.
The car is a stock 04 including wheels and tires.
One day at a light some guys pulled up next to me in a truck wanting to know if I got it up to 200 yet!
Old Mar 8, 2008 | 11:29 PM
diyguy's Avatar
diyguy
Turn Ignition on.
Press and HOLD Options button
Press FUEL button 4 times
Codes will display - C=current
H=history
No need for a scanner.....
Old Mar 8, 2008 | 11:30 PM
KidShalene's Avatar
KidShalene
If it were mine, I'd take it to my dyno guy and have him run it up
till everything went ape-shi t and see wtf was going on...JMHO
Old Mar 9, 2008 | 12:07 AM
Today's problem is..'s Avatar
Cruise-In VI Veteran
St. Jude Donor '09
Do you have different size tires/wheels on the car than stock, or do you have stainless brake lines. I installed stainless brake lines on my car and when I hit speeds of over 120mph, (track only ) I throw wheel speed variation codes for the front left and right wheels. I have been told it is due to the very high speed vibration of the stainless line building up static electricity and then sending a voltage spike into the wheel speed sensor.
Old Mar 9, 2008 | 12:10 AM
clayton1's Avatar
clayton1
Banned Scam/Spammer
Originally Posted by diyguy
Turn Ignition on.
H=history
Its that simple!
Old Mar 9, 2008 | 12:22 AM
DefenderC5's Avatar
DefenderC5
Whaaaaa? When I get back I'm going to have to try that since I have SS lines on mine as well. Sounds a little hokey.
Old Mar 9, 2008 | 04:52 AM
DeeGee's Avatar
DeeGee
I'd be thinking something associated with the active handling
Post up the codes and there are some real experts here who could probably help.
To Odd problem at high speed
