2001 Corvette VIN Decoder
Old Mar 11, 2008 | 05:08 PM
my_blue_c5's Avatar
my_blue_c5
Default 2001 Corvette VIN Decoder
There's a lot you can find out just by your VIN.
1 Country of Origin: USA
G Manufacturer: General Motors
1 Make: Chevrolet
YY Carline/Series: Corvette
2 Body Style: 1=Hardtop, 2=Two door coupe, 3=Two door convertible
2 Restraint Code: 2=Active
G Engine Type: G=LS1 S=LS6
4 Check Digit: Varies
1 Model Year: 1=2001
5 Plant: 5=Bowling Green, Kentucky
118096 Production Number: Between 100001-135627
Have fun.
Old Mar 11, 2008 | 05:41 PM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
And you could find out a lot more if you PM forum member Sponge Vette with your VIN. He can run it through GMVIS and get you all of the service and origination history. It's pretty cool to find out who the originating dealer is, and what service history has been put through GM on the car.
Old Mar 11, 2008 | 05:57 PM
my_blue_c5's Avatar
my_blue_c5
Thanks, I'll be sure and do that.
Old Mar 11, 2008 | 05:58 PM
C5Bagger's Avatar
C5Bagger
Could you explain how to go about this? It sounds real interesting. I bought from a one owner and did a car fax but was clean
Old Mar 11, 2008 | 06:30 PM
my_blue_c5's Avatar
my_blue_c5
C5Bagger,
Running your car through GMVIS shows your all of your service records, as well as the original dealership came from, and that sort of thing. I know that it can show you if your car is a lemon or not, but i'm not to familiar with much else then that.
Old Mar 11, 2008 | 06:49 PM
Sponge Vette's Avatar
Sponge Vette
St. Jude Contributor
Check you PM
Old Mar 11, 2008 | 08:24 PM
blacksedan87
Just as I indicated above - send a private message to Sponge Vette and ask him to run your VIN. He has been doing this as a service to his brothers and sisters here on the Forum for many years. He will either send you a return PM with the information or sometimes he's been known to simply respond in a thread with the information.
All I can say is Sponge Vette is a real asset to the forum, and collectively we owe him big! I'll buy the first round....
Old Dec 23, 2012 | 07:50 PM
flavetteluvr's Avatar
flavetteluvr
1st Gear
Default VIN Decoder - MT or AT
Thank you for the this piece of important information. Is there any way to discern the transmission from the VIN? I have followed up with other sources and it does not seem to be that easily to determine unless you look at th engine block information. Is this truly the case, or is this information embedded in the codes for the VIN?
Much thanks.
Old Dec 23, 2012 | 09:12 PM
Quicksilver Vert 01's Avatar
Quicksilver Vert 01
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16
No. The VIN does not contain that information.
It's listed on the RPO code sticker that's usually located on the inside of the glove box cover, or on the back side of a rear storage compartment cover. The M code on the RPO sticker is relevant to the transmission type.
MM6 or MN6 for manual transmissions, and MX0 for automatic transmission.
Old Dec 23, 2012 | 10:02 PM
Your local dealer can do this also - just ask them.
To 2001 Corvette VIN Decoder
