View Poll Results: What Octane Do You Use
87
5
2.03%
89
10
4.07%
91
94
38.21%
Higher
137
55.69%
Voters: 246. You may not vote on this poll
Old Mar 11, 2008 | 08:38 PM
Dave concrete's Avatar
Dave concrete
Originally Posted by vette_fanatic
I always used 87 and it never been a problem. I know it cant be true but it always feel the best on cheep gas.
Not that I use 87,But these cars will run perfect with 87.
Old Mar 11, 2008 | 08:39 PM
nj02vette's Avatar
nj02vette
From: Marlton. Increasing performance one speeding ticket at a time! NJ
Originally Posted by Y2Kvert4me
Best performance without tune alteration = the lowest octane you can get away with without inducing knock/ping.
Some very wise words to listen too. Higher Octane does not equal better, it's actually just a comparison rating that 93 fuel has similar burn characteristics to a mixture of 93% Octane. That actually means that it is harder to burn the fuel. Premiums actually pollute more.
All else equal, I run premium, though.
Old Mar 11, 2008 | 08:40 PM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
This is the reply from someone who knows.....
Originally Posted by Evil-Twin
This is why I hate some of the posts here,,,,,
The manual says you can use a low octane fuel in a stuck situation.
( what this means is, in the event you need gas and the only station around is out of 91 octane, you can use it to get yo the next station)
the car is not meant to be driven on anything less than 91 octane.
Using less than 91 octane will cause a knock retard condition, reducing ignition timing, and poor performance. It will only cause engine damage over time... the difference between regular and 91 octane is 10 cents.
if you spend 30 dollars a week its 3 dollars, thats 150 dollars a year. if you cant afford that, then you should not buy a corvette. I am not being smart, just honest. Corvettes can be costly to maintain as well. If you are that worried about gas prices what are you going to do with a 75 dollar oil change,or if something goes wrong with the 7 computer modules found in a Corvette, they are all over 500 dollars . water pump is a 500 dollar fix...
a front wheel bearing replacement is 500 dollars... 4 tires are 800 to 1200 dollars.
I'm telling you this like you were my son or brother,.
Good luck
Bill aka ET
You can run 87 octane in YOUR cars - it's your privilege. I will run Premium unleaded Top Tier fuel in mine, because that's how Chevrolet engineered the car to run at it's best, and that's how my car runs best. I just wouldn't want to be the poor dumba$$ that buys the car used from you guys running 87 octane in them all the time.
Old Mar 11, 2008 | 08:45 PM
LEANDRO's Avatar
LEANDRO
e-85 105 octane
RedRckC5's Avatar
RedRckC5
Ran Amoco 93 back in the days with my Typhoon and now, I can only find 91 Chevron here in Vegas.
Old Mar 11, 2008 | 08:47 PM
Corvette-Chris's Avatar
Corvette-Chris
St. Jude Donor '08
Unless you are seeing KR under a WOT load...it will feel no different.
If you can tune specifically for that fuel, and get some timing advance out of the deal, then perhaps....
Actually I am getting knock when I spray. But I am going back to LG next week to see if they can work it out
Old Mar 11, 2008 | 08:48 PM
Plasticfan's Avatar
Plasticfan
93 octane Chevron.
Old Mar 11, 2008 | 08:49 PM
tiojames's Avatar
tiojames
Old Mar 11, 2008 | 09:01 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
Anyone with tuning software knows.
E-T obviously had no part of the PCM programming logic.
Under normal operating conditions, the PCM uses two basic (fixed) timing tables...a high octane table, and a low octane table. It will normally reference the high octane table, and set timing as such, until the point knock is detected.
If a slight amount of knock is detected (long before audible), the PCM will set the timing somewhere in between the values of the high/low tables, and yes, it is always in a constant state of readjustment.
When knock is no longer detected, timing will be advanced again.
The only time the PCM will fully switch to the low octane table is if a MAF or knock sensor DTC has been set.
The use of 87 octane will NOT damage the engine over time, and won't even cause the PCM to run solely from the low octane timing table. It MIGHT cause the actual timing to be slightly retarded during operation, yes, affecting performance, , but never below the low octane table, which is still plenty safe for the engine.
Old Mar 11, 2008 | 09:08 PM
e6bailey's Avatar
e6bailey
93 Marathon
speedsk899's Avatar
speedsk899
Did you have any timing taken out? I pulled 2 degrees for 150 shot!
Old Mar 11, 2008 | 09:18 PM
TopFuelTim's Avatar
TopFuelTim
93 for me. Can use 87, car just doesn't really like it.
Old Mar 11, 2008 | 09:42 PM
  #33
Normally 91 octane, but have used 89 octane before with no knock or pinging noticable.
Old Mar 11, 2008 | 09:46 PM
  #34
steve8's Avatar
steve8
91 minimum.
  #35
Bob CTS's Avatar
Bob CTS
Here we go again, I use 93, if you are running 87 just because you think your saving money maybe you should look at a KIA.
Old Mar 11, 2008 | 09:50 PM
  #36
clayton1's Avatar
clayton1
Banned Scam/Spammer
91 Chevron.
  #37
yaknow's Avatar
yaknow
91 or higher
To What Octane Do You Use
Old Mar 11, 2008 | 09:52 PM
  #38
Quick Silver Z's Avatar
Quick Silver Z
No-IL Events Coordinator
2025 C6 of the Year Winner - Unmodified
2019 C6 of Year Winner (appearance mods)
2018 C6 of Year Finalist
St. Jude Donor '12 thru '26
93 Shell V-Power in my V8!
Old Mar 11, 2008 | 10:18 PM
  #39
nextime's Avatar
nextime
I have been using Premium since I bought the car, my friend has had his Vette for years and said a GM tech told him he could run 87 in it cause the computer would compensate for the difference.
I only use Premium but wanted to know if this was true. Now I know it is true but cheap-o's are the only ones running the 87.
Old Mar 11, 2008 | 11:15 PM
  #40
Double D Mods's Avatar
0Double D Mods
Former Vendor
St. Jude Donor '12-'13
