View Poll Results : What Octane Do You Use
Mar 11, 2008 | 07:00 PM
What Octane do you use?
Mar 11, 2008 | 07:01 PM
Cruise-In VII Veteran
St. Jude Donor '05 thru '19
Mar 11, 2008 | 07:03 PM
Sunoco gold 94
Mar 11, 2008 | 07:05 PM
Sinclair used to carry 93 but now I can only find 91. Anyone know where you can get higher than 91 in Oklahoma City?
Mar 11, 2008 | 07:07 PM
I sometimes hear you can run 87 and the computer will adjust to it and no harm done, is this true?
Mar 11, 2008 | 07:28 PM
exxon 93 only cheaper gas will cause ur car to knock
Mar 11, 2008 | 07:31 PM
91, the maximum available here at the top of the continent, in Colorado.
Mar 11, 2008 | 07:35 PM
I always used 87 and it never been a problem. I know it cant be true but it always feel the best on cheep gas.
St. Jude Donor '08
93.....there is a place to buy 104 unleaded and I really wanna see how that feels
Mar 11, 2008 | 07:45 PM
Quote:
Originally Posted by
nextime
Yes, New cars all have knock sensors that will retard timing to match the octane you put in the tank. Depending on the kind of driving you do, you may not notice the difference. However, if you take your car to the track, you certainly don't want to run with retarded spark. Your competition will be using the good stuff and maximum spark advance.
Mar 11, 2008 | 07:48 PM
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
Corvette-Chris
Unless you are seeing KR under a WOT load...it will feel no different.
If you can tune specifically for that fuel, and get some timing advance out of the deal, then perhaps....
Best performance without tune alteration = the lowest octane you can get away with without inducing knock/ping.
Mar 11, 2008 | 07:50 PM
CentralTX Events Coordinator
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17
93, Chevron if possible.
Mar 11, 2008 | 07:53 PM
I think 91 is the highest here in Tucson. I know Chevon & Shell are 91, but I'm never checked Exxon.
Mar 11, 2008 | 07:54 PM
Shell 93 a Tier1 gasoline
Mar 11, 2008 | 07:59 PM
91 is about all you can get around here.
Mar 11, 2008 | 08:06 PM
St. Jude Donor '12 thru '21
Cozmo
Same here
Mar 11, 2008 | 08:24 PM
Mostly I use 93 but I will use anything 91 or higher.
Mar 11, 2008 | 08:32 PM
for some reason my stock vette pings like crazy under aggressive driving with 91 octane fuel. i have to use 104 octane booster for it not too. dont know why that is.
Mar 11, 2008 | 08:36 PM
From: This is not a Song, It's an Outburst: Or, The Establishment Blues; Sixto Diaz Rodriguez
Chevron 93 is readily available where I am.
Mar 11, 2008 | 08:37 PM
why would you want to use 87 in a performance car? I use 93! and I spray 150 shot at it. No problems
