negative camber normal?
Old Mar 21, 2008 | 12:43 AM
cosvette's Avatar
cosvette
Default negative camber normal?
I had a 4-wheel alignment done today and there was a minor difference in front tire tread wear (GY runflats). Inside tread was slightly more worn than outside. The technician said this was due to the negative camber setting, which is the normal setting for my '99 Coupe.
It's a 50+ year shop, very well respected and professional, and I'm sure they were shooting straight with me, but it did seem strange that I can expect my tires to wear out on the inside first.
Anyone else had any experience with this? Is it "normal?"
Old Mar 21, 2008 | 02:12 AM
OleStraightStick's Avatar
OleStraightStick
St. Jude Donor '08
i'm no expert but i wouldn't think so?
Old Mar 21, 2008 | 02:19 AM
carnut101's Avatar
carnut101
Definitely normal for any car set up for corners (like corvettes). All that the inside wear means is that you arent pushing your car hard enough in the corners.
Old Mar 21, 2008 | 02:46 AM
Lancer033's Avatar
Lancer033
in other words, your car is set up to be driven more aggressively than you drive. Either hit the corners harder or back off on the camber until you get even wear.
Old Mar 21, 2008 | 07:31 AM
moserbe's Avatar
moserbe
I have the same issue with the GY runflats that I just took off of my car. I put on new Michelin runflats and will be taking it in for an alignment soon. Hopefully these tires wear evenly.
Old Mar 21, 2008 | 08:53 AM
DefenderC5's Avatar
DefenderC5
All sports cars will have some amount of negative camber... it's normal.
Old Mar 21, 2008 | 03:59 PM
fatboytc88's Avatar
fatboytc88
the inside of both my front tires are worn on my 04 vert. plenty of tread on outside . 27,000 miles on runflats. so maybe this is normal.
Old Mar 21, 2008 | 04:10 PM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
C5 Service Manual Alignment --- Source
Front Individual Toe +0.04 degree
Front Sum Toe +0.08 degree
Front Individual Caster +6.9 degree
Front Cross Caster within 0.50 degree
Front Individual Camber -0.20 degree
Front Cross Camber within 0.50 degree
Rear Individual Toe -0.01 degree
Rear Sum Toe -0.02 degree
Rear Individual Camber -0.18 degree
Rear Cross Camber within 0.50 degree
Z06 Service Manual Alignment --- Source
LEFT & RIGHT FRONT:
Camber: Specified Range: -1.2 to -0.2 Optimal: -0.7
Caster: Specified Range: 6.4 to 7.4 Optimal 6.9
Toe: Specified Range: 0.15 to 0.25 Optimal 0.20
FRONT
Cross Camber: Specified Range: -0.5 to 0.5 Optimal: 0.0
Cross Caster: Specified Range: -0.5 to 0.5 Optimal: 0.0
Total Toe: Specified Range: 0.30 to 0.50 Optimal: 0.40
LEFT & RIGHT REAR
Toe: Specified Range: -0.06 to 0.05 Optimal: -0.005
REAR
Total Toe: Specified Range: -0.11 to 0.09 Optimal: -0.01
Thrust Angle: Specified Range: -0.10 to 0.10 Optimal: 0.00
http://forums.corvetteforum.com/showthread.php?t=984927
As you can see from the above - both the regular C5 and the Z06 OEM alignment specs call for negative camber. did the alignment shop provide you with a printout of the specs that your car has been set to so you can compare?
Old Mar 21, 2008 | 05:38 PM
tiojames's Avatar
tiojames
The vettes run neg camber and this causes our tires to wear usually more on the inside. You can have it reset, but give up handling. I took my wheels in about half way worn(on the old run flats) and had the tires reversed so the wear was on the outside and wore them out back to even.
Old Mar 22, 2008 | 01:12 AM
cosvette's Avatar
cosvette
The only way I can think of to reverse the tires and maintain directional integrity is to put the tires inside out on the opposite wheel. Is this what you did? How did they look and how much additional wear do you estimate you got by doing this?
If I've missed a better way to reverse the tires, forgive me. It's late and I'm worn out from throwing a sponge "brick" at the tv repeatedly as my team lost big time in the first round of "the dance."
Old Mar 22, 2008 | 01:59 AM
SebringSixSpeed's Avatar
SebringSixSpeed
Old Mar 22, 2008 | 08:08 AM
AU N EGL's Avatar
AU N EGL
Stock or OEM alignment specs are more the maximum tire ware AND taking in consideration the crown of most roads, not performance.
Old Mar 22, 2008 | 09:19 AM
Bugaboo's Avatar
Bugaboo
I'm thinking of trying 0 camber soon for primarily daily driver and highway use??
To negative camber normal?
