Headlights in the OVEN?
Old Mar 23, 2008 | 03:16 PM
MarczZ06's Avatar
MarczZ06
Default Headlights in the OVEN?
Has anyone heard of putting your headlights in the oven to make them clear again? If so, what's the proper technique of doing so?
Old Mar 23, 2008 | 03:29 PM
Cocked and Locked's Avatar
Cocked and Locked
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17
Bake at 350 for 2 1/2 hours, or until golden brown, on a greased cookie sheet.
Seriously though, in my time here I've never heard of that, and there have been a LOT of headlight threads. Good luck.
Old Mar 23, 2008 | 03:33 PM
WildTurkey's Avatar
WildTurkey
....and nice avatar
Old Mar 23, 2008 | 03:38 PM
02MillenniumVette's Avatar
02MillenniumVette
Ive heard of it before but I dont remember the reason for putting them in there. And I dont know on what temp. and for how long.
Old Mar 23, 2008 | 04:30 PM
Carz4Toyz's Avatar
Carz4Toyz
If there is condensation inside the oven will dry them out. If the plastic is cloudy/oxidised the oven will do you no good short of melting the plastic to a point where it is clear. Of course you probably couldn't use them aymore.....
Old Mar 23, 2008 | 04:34 PM
robert miller's Avatar
robert miller
Old Mar 23, 2008 | 04:45 PM
carnut101's Avatar
carnut101
I had to put mine in the oven to split the headlights apart for my HID projector retrofit. Not sure if it'll do anything for condensation. I warmed my oven to 250 degrees, turned off the oven, and stuck in the headlights for 10 minutes.
Old Mar 23, 2008 | 04:48 PM
jrose7004's Avatar
jrose7004
I've never heard of that one!
Old Mar 23, 2008 | 05:39 PM
C5R USA's Avatar
C5R USA
From: Ideals are peaceful...History is violent...St.Charles, MO.
C5 of Year Winner (appearance mods) 2019
St. Jude Donor '08-'09-'12 thru'22
Old Mar 23, 2008 | 05:40 PM
DeeGee's Avatar
DeeGee
Step away from the oven
Seriously, they're plastic. Not a good idea
Old Mar 23, 2008 | 06:35 PM
waunavet's Avatar
waunavet
St. Jude Donor '20
I've heard of people putting their head in an oven but not a headlight. Although doing so could make your head light. Sorry, I just had to. Keep the oven for baking food.
Old Mar 23, 2008 | 06:39 PM
damilleniumboy's Avatar
damilleniumboy
We have an few ovens/incubators that reticulate air at work, and i bet that will keep a much more even effect on whatever you think will happen . There is also a muffle/Incinerator that goes up to 1000+ degrees Fahrenheit; I’m pretty sure that will take every single impurity out of the lenses.
Old Mar 23, 2008 | 07:18 PM
IM28702's Avatar
IM28702
I too have used the oven method to split open lights, but I did it on another car so I could paint the inside of the housings.
If you want to get rid of the haze, use polycarbonate polish. Look for a plastic shop in your area, most of them will have it in stock.
Old Mar 23, 2008 | 07:23 PM
blkchipC5's Avatar
blkchipC5
I wouldn't do the oven thing but I have used CLR in the green bottle, or a Powerball before on other headlights and both worked like a charm.
Old Mar 23, 2008 | 07:56 PM
jacks996's Avatar
jacks996
Jacks996
Cruise-In VIII Veteran
I would try this first. they are plastic
Old Mar 23, 2008 | 09:20 PM
Haven't heard of the oven trick - I'd be afraid I'd damage the headlight.
Old Mar 23, 2008 | 09:23 PM
CJR2's Avatar
CJR2
St. Jude Donor '08
To Headlights in the OVEN?
Old Mar 23, 2008 | 09:31 PM
Corvette-Chris's Avatar
Corvette-Chris
St. Jude Donor '08
Thats because its not the oven.....Everyone knows you have to put them on the grill
Old Mar 23, 2008 | 09:34 PM
HUMVET51's Avatar
HUMVET51
Just to play it safe, find a nice sunny spot around the house and leave them there all day. that should be the safe way and if that doesnt work then stick em in the oven.
Old Mar 23, 2008 | 09:38 PM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
I have heard of putting a few things in the oven and head lights isn't one of them, They do sell a polishing kit that will remove the faded layer off the head lights. Never use it though...
Bill K
