I've never heard of sticking a headlight in the oven. I don't think it will do any good. My DD is a Dodge Pickup. The headlight lenses were cloudy and yellow. I bought some stuff in a bottle from the auto parts. It's made by Blue Majic, and it called Headlight Lens Restorer. It claims to "Remove Yellowing, Restore Optical Clairity, Improve Visibility and Safety. and Prevent Re-yellowing". It worked for me as advertised.
We used to put spark plugs in the oven and put the oven setting on "clean". It made the plugs look brand new. Never heard of putting headlights in though.
The point of putting headlights in the oven is to melt the adhesive holding the lense to the body of the headlight. It's not like you leave them in there forever, you aren't going to damage anything.
Back to the OP's post. Simply baking your headlights isn't going to make them bright again. Try wetsanding them...
I had a jeep grand cherokee whose headlights had been badly damaged and hazed from being over-exposed to our Kansas sun, and I used plastic x from meguires to polish the lenses with a 6" polisher, so after polishing for an hour per lens they were good as new. It did took me some work to get them to be clear again though.
Oh, and I also did the same thing to my 1993 bimmer like four years ago, and it also worked. The lenses are somewhat layered after they have been over exposed to the sun and have developed the haze, so if you do my weird method it's just one thing I should point out. I think that happens because the oxidized part of the lens is the first to get polished away, but just my .02 cents.
Not naive, just dont think putting plastic in an over is a great plan. I can think of lots of ways to melt the adhesive but I'd use plastic polish for this job
