What Wheel is This?
From the shine, the front side does look like the clear coating was stripped off and then the wheel was polished to a shine and kept up regularly.
If you have some aluminum polish try a little on it. If the rag comes off black then it's aluminum.
Peter
I can definitely say the back side of the rim does not look like it was chromed. I can also say I have not seen enough C5 wheels to know what these are. The build sheet for the car does show it was ordered with the optional high polished aluminum wheels. The picture of those wheels in the sales brochure shows the center caps with logos (mine have none) and the finish appears to be more dull then my wheels. I'll find some aluminum polish and try that.
You could get aluminum to look that bright, but it wouldnt be easey, and unless you cleared them kepping them like that would be a lot of work.
Try the polish thing on a small area, if it comes back black, they are probably either uncleared chrome or aluminum. If it comes back grey or clean, they are probably cleared (just wax em just like you do the rest of the car and they will always look that good).
Whatever they are they look good
I replaced the decals on my center caps. Try looking for Cyberdine Graphics. They make a 3d (raised) logo that looks outstanding on the wheels. Followed the installation instructions (area has to be squeeky clean) and put them on two years ago. They look as good now as the day I put them on (and I was the car a lot and have put about 20,000 miles on it with them on).
If they are clear coated you should be able to tell pretty easy. You can see the clear layer over top of the aluminum.
In the front pic they do look chromed but looking at the back pic they're just aluminum. Any chrome wheel I have seen was all chrome.
After looking again I'd say it could be possible they have a clear coating on them and the camera just took a great shot but then, once again, you should be able to tell there is a coating pretty easily.
Peter
Peter
They came on the coupes and Verts!
Here is a link to some center caps and decals:
http://search.ebay.com/search/search...aps&category0=
Thanks,Matt
