How Much Does Cold Air Effect HP
Old Mar 27, 2008 | 09:24 PM
Montezumas_Viper's Avatar
Montezumas_Viper
Default How Much Does Cold Air Effect HP
With a cold air intake on a C5 how much does it affect you? I've noticed a very big difference from the common 15 degree temps in the winter in Kansas and the 100+ temps in the summer.
So how much of a difference does it make?
Old Mar 27, 2008 | 09:33 PM
Montezumas_Viper
From what i've read its 1% per every 7 degrees. On a stock engine thats over 45hp from 15 degrees to 100 degrees
Old Mar 27, 2008 | 09:36 PM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
it's 1.7 hp every 10 degrees F.
Sorry I made a mistake here...Im human too. its 1.5 % for every 10 degrees this is the % used to calculate corrected and uncorrected dyno numbers.,..For C5's
Old Mar 27, 2008 | 09:39 PM
peter pan's Avatar
peter pan
Life Time NCM #2196
More like 14.5 hp......
I like that, I know my boosted Vette loves the cold weather, just not the tires
Old Mar 27, 2008 | 09:43 PM
Montezumas_Viper
Good, I can deal with 14.5
FactoryRaceCar's Avatar
FactoryRaceCar
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12
My car is an absolute beast in cold weather. Tires are a different story though
Old Mar 27, 2008 | 09:45 PM
Montezumas_Viper
So is might and its not FI. The same went for the LT1 camaro I had, it just seems like it has so much more power in the cold especially when going onto and onramp when you have traction.
Must be an illusion...
Old Mar 27, 2008 | 09:50 PM
Silverbullet00's Avatar
Silverbullet00
From: Norman Oklahoma - The Only State in the Union with no Blue Counties!
Fixed it
Old Mar 27, 2008 | 10:14 PM
Luv2Run's Avatar
Luv2Run
St. Jude Donor '13
Interesting, here is published research...
HP Output =
+1% HP per 10 degree temperature decrease
-1% HP per 10 degree temperature increase
One source here...(google is your friend)
http://www.banzairunnerpantera.com/t...techinfo_calcs
and a calculator so you do can do you own analysis
http://wahiduddin.net/calc/calc_hp_dp.htm
It's more about the density of the air and temp is only one factor of density.
But I guess when you feel it...nothing else matters
Don
Old Mar 27, 2008 | 10:50 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
Of course it's going to be a percentage.
I assure you my 5hp snowblower on a 30 degree day does not make 10hp on a 0 degree day.
Since this is the C5 forum, it is safe to assume a 700hp blown C5 packing the cylinders with more of that oxygen-rich air will develop proportionally more hp gain in cold weather than the stock 345hp car will in the same conditions.
Volumetric efficiency is not a constant. Think about it....
Old Mar 28, 2008 | 12:40 AM
flyzlow's Avatar
flyzlow
I can feel a huge difference in cool weather in comparison to our typical hot temps in Phx.
Old Mar 28, 2008 | 03:01 AM
gpracer1's Avatar
gpracer1
Not to mention we probably get timing pulled also when the air is 115 in the freakin shade
Old Mar 28, 2008 | 03:21 AM
flyzlow's Avatar
flyzlow
Old Mar 28, 2008 | 03:22 AM
dieseldave56's Avatar
dieseldave56
Default Only know this................
I only know that with my trubo charged '87 Grand National that two (2)degrees of temp drop ( out of the inter/outer cooler) add one (1) hp over ambient temps.
Old Mar 28, 2008 | 08:35 AM
bucwheat's Avatar
bucwheat
Ever notice how some people ice down their motor between runs at the track,it works.
Old Mar 28, 2008 | 08:57 AM
AU N EGL's Avatar
AU N EGL
Peter you are correct. the engine loves cold air 50-55* but the pavement is too cold, and the tires are too cold so there is minimal grip.
Old Mar 28, 2008 | 09:57 AM
2003VETT's Avatar
2003VETT
From: Still the Fastest (still running) Stock Bottom End Blown LS1/ 2010 ECS CC 10.50 CHAMP Hamilton, NJ
Simple terms:
40 degrees = 10.30's
90 degrees = 10.90's
That was on my car! lost about 4-5 mph
To How Much Does Cold Air Effect HP
Old Mar 28, 2008 | 11:24 AM
miami993c297's Avatar
miami993c297
EXCELLENT
Do you take in account the temperature sent by the IAT Sensor or is this 1.5% value an SAE outside temperature value?
Christian
Old Mar 29, 2008 | 02:11 PM
Montezumas_Viper
Originally Posted by miami993c297
EXCELLENT
Christian
This amounts to over 35hp from the dead of winter to the hottest months in summer (Kansas).
Old Mar 29, 2008 | 02:31 PM
tiojames's Avatar
tiojames
Another factor to consider is altitude. My snow blower came with a blurb that said it would lose a little over 2% of its horsepower for every 1,000 feet of elevation over sea level. Considering it's only 10 HP and we are at 7,000 feet it ain't got de horses it needs here in the deep snow so we modified the intake and exhaust. It did make a difference. It affects my vert also to the extent you can tell it.
