Mods are backing up....
This is what I have to do and I've got all the pieces. Just need the time and energy to get them done...
1. R&R bowtie valve covers and drill and tap for AN fittings and vent lines.
2. Replace the right side fuel tank cover damaged by large rock in road.
3. Replace the sub amp and clean up the system wiring. - DONE!
4. Install the Crazy Cowboy cockpit insulation kit. DONE!
5. Remove BP Vortex and install Halltech Venom AAIS and shorten/cleanup MAF wiring
6. Change out the stands in the RAM Dual Disk Clutch through inspection plate. May have Ed Hutchings do this.
7. Install cutouts. I've got a local shop to do this but I will need to wire them.
8. Install new style shaft in the MGW shifter - DONE!
DAMN!!! The list is longer than I thought.
I really need to have a mod party.
AND.....The DMH low profile cutouts were delivered!
I need a nap..
UPDATE: Just took the car for a short drive. The insulation kit definitely quieted things up...Worth while mod!
That is a nice list though and can not wait to here the vid from the cutouts
