Help
Old Apr 8, 2008 | 09:28 PM
Joe aka - KODAK's Avatar
Joe aka - KODAK
Default Help
Can anyone tell me the torque for the thermstat bolts and should I use lock tight?
Old Apr 8, 2008 | 09:34 PM
JPM@AutoBuffs's Avatar
0JPM@AutoBuffs
Former Vendor
From: The AutoBuffs Army is unmatched in the Custom world! www.autobuffs.net
S. Jersey Events Coordinator
St. Jude Donor '08-'09-'10
Cruise-In IX Veteran
You speaka da english?
Old Apr 8, 2008 | 09:36 PM
Joe aka - KODAK
Hey I'm Italian and it takes me a while!
Old Apr 8, 2008 | 09:39 PM
MagRedConv's Avatar
MagRedConv
Old Apr 8, 2008 | 09:40 PM
0JPM@AutoBuffs
Former Vendor
Im italian too...but god I dont have to warm up...
Old Apr 8, 2008 | 09:44 PM
Joe aka - KODAK
Well, so what - do you have an answer that would help - or are you just going to needle me? Seems like a legitimate question.
Old Apr 8, 2008 | 09:47 PM
0JPM@AutoBuffs
Former Vendor
Im sure someone will jump in and answer the said question.
Good Luck
Old Apr 8, 2008 | 09:48 PM
MagRedConv's Avatar
MagRedConv
Hey Joe, the search function is a powerful tool -
http://forums.corvetteforum.com/show...rmostat+torque
No more freebies!
Old Apr 8, 2008 | 09:49 PM
Blue 92's Avatar
Blue 92
CI 3-4, 8-9-10 Veteran
St. Jude Donor '06-'08-'10
Can anyone tell me the torque for the thermstat bolts and should I was an lock tight?
Install the water pump inlet (with thermostat).
Notice
Use the correct fastener in the correct location. Replacement fasteners must be the correct part number for that application. Fasteners requiring replacement or fasteners requiring the use of thread locking compound or sealant are identified in the service procedure. Do not use paints, lubricants, or corrosion inhibitors on fasteners or fastener joint surfaces unless specified. These coatings affect fastener torque and joint clamping force and may damage the fastener. Use the correct tightening sequence and specifications when installing fasteners in order to avoid damage to parts and systems.
Install the water pump inlet bolts. Tighten
Tighten the water pump inlet bolts to 15 N·m (11 lb ft).
Old Apr 9, 2008 | 09:56 PM
robsc501's Avatar
robsc501
Default Help
Hey Joe,
Fill out your profile.What year vette?BTW the bolts are 89inch lbs. No lock tite required.
GM p/n is 12571261
robsc501
To Help
