I'm going to pull this module tomorrow using the instructions above - should I disconnect the battery and/or pull the fuses first?
As a rule of thumb, if you are going to leave the hood open for more than a few hours, it's always a good idea to disconnect the battery. My hood liht goes out, automatically after a number of minutes, but everytime I bump it, it comes on again. While my EBCM was out getting fixed, I left the hood up and drove my other car.
Thanks for all the kind words, everyone. Mr. Moderator, I won't mind if you make the procedure or its link a sticky.
Put the module back in yesterday and (aside from the C4-like component access ) all went smoothly. Cleared the codes and all looks good. I'll also put in another good word for ABSFixer...
Pulled my module using these excellent instructions as well, although I ended up removing the upper radiator hose as well. I happen to have freakishly large hands, and there was no way I was getting my torx driver into that tight area without doing this. Shipped the module off to Brandon on Wednesday. Hope his shop isn't under water! Will USPS deliver to a lake?
It can get to be confusing, but from what I understand, the EBCM is sometimes referred to as the EBTCM (Electronic Brake Traction Control Module) which bolted to the BPMV (Brake pressure modulating valve.)
From: If opportunity doesn't knock, build a door. South West Florida / Livin' The Dream
St. Jude Donor '12
Dave, great write up. This write up will save folks thousands of dollar.
I had my EBCM go out a couple of years ago and a similar write up by forum member Bill Curlee turned me on to doing it myself. I took the money Bill saved me and bought now S/D rotors and Hawk Ceramic pads.
You know you have to spend what you save doing your own work on more Mods!
Without forums, we'd all be a bit poorer. In fact, I'll bet some people could not afford to have a C5 without using the DIY stuff that can be found in this and other forums. I just wish this were in existence during my earlier C3-ownership days!
