Oil Catch can question...
Old Apr 22, 2008 | 10:05 AM
ALVETTE00's Avatar
ALVETTE00
Default Oil Catch can question...
Is the PCV valve still needed if you have the catch installed?
If so, why?
Also, on the LS1, is the thick cable thats attached from the PCV valve to the block needed?
Thanks,
al
Old Apr 22, 2008 | 10:26 AM
GRUNIE's Avatar
GRUNIE
Old Apr 22, 2008 | 10:57 AM
LMH4C5's Avatar
LMH4C5
St. Jude Donor '08-'09-'10
National Champs Gators 4 St. Jude '09
Originally Posted by GRUNIE
Old Apr 22, 2008 | 11:46 AM
ALVETTE00's Avatar
ALVETTE00
Might as well!
Old Apr 22, 2008 | 01:33 PM
jon c's Avatar
jon c
Originally Posted by ALVETTE00
Might as well!
Old Apr 22, 2008 | 01:44 PM
jmc12's Avatar
jmc12
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17
yes it should be... Every thing I read about it said but it in.. I just had mine installed yesterday...
By the way what does mean?????
Old Apr 22, 2008 | 01:55 PM
hotwheels57's Avatar
hotwheels57
...pass your mouse cursor over any icon and it'll tell you the meaning...
Old Apr 22, 2008 | 02:22 PM
nextime's Avatar
nextime
Yeah I have the same question?
Old Apr 22, 2008 | 02:55 PM
ALVETTE00's Avatar
ALVETTE00
I have faith someone will have the answer. We've got enough popcorn here to watch Titanic 10x back-to-back
Old Apr 22, 2008 | 03:51 PM
Dave68's Avatar
Dave68
This article explains why we need a PCV valve. Hint: the PCV and a catch can have different functions.
http://www.conceptualpolymer.com/PCV...oval%20101.pdf
Old Apr 22, 2008 | 04:31 PM
kornfreak_401's Avatar
kornfreak_401
^ thats an intersting article BUT I still think that not putting the pcv valve on after installing a catch can is not going to make a significant change.
J
Old Apr 22, 2008 | 05:04 PM
itzza427's Avatar
itzza427
I say keep the valve as it controls the flow and crank case pressure.The catch can only helps condense some of the oil vapors and keep it from gumming up the intake tract. Unrestricted flow would probably overwhelm the small volume of the can.
Old Apr 22, 2008 | 05:26 PM
CCA Corvette Parts's Avatar
CCA Corvette Parts
Premium Supporting Vendor
St. Jude Donor '07-'08,-'13-'14, '16-'17
...because air needs to flow out, not in...
Peace
Chip
__________________
..................Click for
Old Apr 22, 2008 | 06:18 PM
nextime's Avatar
nextime
OK..... still what about the cable attached to the PCV, does it stay attached or can it be removed?
Old Apr 22, 2008 | 06:21 PM
CCA Corvette Parts
Correct me if I'm wrong everyone, but it is just there to hold the unit in place... so it can come out if you don't like it...
Peace
Chip
Old Apr 23, 2008 | 09:47 AM
ALVETTE00's Avatar
ALVETTE00
As for the cable, I thought it was a ground of some sort.
Seems odd to me that GM would use such heavy gauge cable to secure a PCV valve!
Old Apr 23, 2008 | 09:48 AM
ALVETTE00's Avatar
ALVETTE00
Thanks for the info Chip.
To Oil Catch can question...
