Oil question
Old Apr 23, 2008 | 08:24 AM
killain's Avatar
killain
Oldtimer
Default Oil question
I know this sounds kinda dumb, but I was wondering about mobil one oil. I have always uesd Mobil 1 10-30 but I was wondering if I should be using 5-30? The owners manual says either is perfectly ok? just wondering what you guys think?
Old Apr 23, 2008 | 08:36 AM
steve8's Avatar
steve8
5-30 here.
Old Apr 23, 2008 | 08:37 AM
jrose7004's Avatar
jrose7004
It depends on temperature and operating conditions in your area.
Old Apr 23, 2008 | 08:39 AM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
I actually use 20W 50 Mobile 1 in my SC Forged motor - LS1 347 CID! and used it on the stocker before as well!
Thanks,Matt
Old Apr 23, 2008 | 08:57 AM
pmuney's Avatar
pmuney
I think most P.A are using 5-30 from my limited experience.
Old Apr 23, 2008 | 09:00 AM
OIF2XVET's Avatar
OIF2XVET
I use 10-30 but I also use royal purple as my oil of choice.
Old Apr 23, 2008 | 09:52 AM
Fly-N-LOw's Avatar
Fly-N-LOw
Default Oil
5-30 is the oil of choice for most areas
Old Apr 23, 2008 | 10:02 AM
LMH4C5's Avatar
LMH4C5
St. Jude Donor '08-'09-'10
National Champs Gators 4 St. Jude '09
I think the majority of C5 owners use 5-30. Another topic that will bring a rash of different opinions.
Old Apr 23, 2008 | 10:03 AM
rws.1's Avatar
rws.1
5W30 is preferred... Use it in all my vehicles...
Old Apr 23, 2008 | 11:33 AM
Mr. Jean's Avatar
Mr. Jean
5-30 here too.
Old Apr 23, 2008 | 12:02 PM
JC in XTC5's Avatar
JC in XTC5
If you don't drive in the winter, then 10W-30 is fine. When I lived in Florida that's what I used but now use 5W in NE just because I'm in broader temp range and my take it out during the winter.
If you look at the specs of M1 5W and 10W there's very little difference.
Old Apr 23, 2008 | 01:49 PM
thisMSGgood4me's Avatar
thisMSGgood4me
Since you live in PA, 5W30 would be the better choice, simply due to your cold winters.
Old Apr 23, 2008 | 03:06 PM
Dave68's Avatar
Dave68
I spoke to a Mobil 1 technical specialist a while back about this very topic. He told me that essentially, 10W-30 Mobil 1 is not needed (obsolete). He went on to say that even at 70 degrees F, 5W-30 flows through your engine faster than does 10W-30 and since startup is when most of the wear occurs to your engine internals, 5W-30 is the better choice. He went on to tell me that he, himself uses 0W-40 in Texas, where it gets fairly hot.
In summation, stick with 5W-30, 0W-30, or 0W-40 synthetic oils (non-heavily built LS1s or LS6s); your engine will last longer, all other things being equal.
Old Apr 24, 2008 | 06:41 AM
killain's Avatar
killain
Oldtimer
Thank You! The last few winters have been pretty mild, it gets down to 10 degrees for mabye a day or two but mostly is at 18 to 25 in January and february but I don't drive all that much and change to oil once a year, so Mobil 5-30 is most likely the best choice !
Old Apr 24, 2008 | 04:51 PM
robsc501's Avatar
robsc501
HI Jim,
Here in central pa. not to far from you, its 5w-30
robsc501
Old Apr 24, 2008 | 05:14 PM
av8or's Avatar
av8or
Just an observation... my daily driver Honda CR-V manual shows one, and only one recommended oil, 5-w20. The engine is just 2.4CC, and typically (for Honda) high-reving. The point? I think advances in metalergy and the closer tolerances in modern engines is reason for us to reverse old notions about engine oil. I used to always worry about my oil being too thin to protect. (remember when 20W-40 was commonly used in new cars?) Now maybe we should be concerned about using an oil that is too viscus (is that the right word for thick?) to circulate quickly on cold startup, where major wear can occur.
Old Apr 24, 2008 | 05:21 PM
rcs128's Avatar
rcs128
Man, that thing must be slow...
To the OP, I use 5W-30 here in the DC area, and our climates is pretty similar to yours. Because I have summer tires on the car all year round, I don't drive it if the temp is any lower than 35-40 degrees anyway.
To Oil question
Old Apr 24, 2008 | 05:29 PM
av8or's Avatar
av8or
[QUOTE=rcs128;1565170170]Man, that thing must be slow... /QUOTE]
Geez, does CM sound any better? Anyway, about 144 CI. Still slow compared to my C5.
Old Apr 24, 2008 | 09:33 PM
Patman's Avatar
Patman
The trend is definitely moving towards thinner oils, and there will be a time soon when all cars come with 5w20 or 0w20 as the specified viscosity, and we'll be referring to 5w30 as the thick oil!
When an engine is designed to run on 5w20, it's perfectly safe, and you won't kill your engine with that viscosity. As strange as it sounds, a lot of people refused to run 5w20 in their engines, thinking it would cause them an early death, even if the owner's manual called for it. But guess what, these engines running on 5w20 are not failing early like many naysayers thought! Even under hard use, such as police cars, or people that do a lot of towing in high heat, these engines are going 200,000 miles and beyond. And the oil analysis results on these engines are proving that engine wear is good. In fact, I've switched my wife's 2000 Civic over to 5w20 and the oil analysis results are excellent. Her owner's manual originally specified 5w30, it was the last year Honda called for 5w30 in the Civic, but they later released a TSB saying the 2000 Civics could run 5w20. Her engine turns over faster on a cold morning, and even revs a little more freely with the thinner oil.
Old Apr 25, 2008 | 12:20 AM
The NNIAL8R's Avatar
The NNIAL8R
St. Jude Donor '11,'13
"I voluntarily took 60 days off from OT"
Damn..Id do ANYTHING to get my wife's "engine" to turn over faster on a cold morning..getting her to "rev a little more freely" would be nice too!!!!
