Well I reprogramed my TPS'S yesterday. The bad one did not reset but I do have another question. Do you buy a left rear one , a left front one,a right rear one and a right front one? The reason I ask is the right rear did not reset but it shows 30lbs on the dic and the left rear reset and shows xxxx's. Could they be reversed and the right rear be bad?
Training tells the car which TPS is on which corner.
I understand this but when it said to train right rear it did not "beep" the horn. When I trained the left rear it beeped but the left rear shows xxx's for tire pressure and the right rear shows 30lbs.
Your car is a '99 and if those are the original sensors, they are near the end of their life cycle anyway. The TPS sensors are not corner specific, so just buy one and have it installed. You will of course have to retrain all the sensors once you get it installed.
I have a couple circular magnets with a hole in them so it will fit around the stem for $14 shipped if you need one.
Sounds like what happend to me and I ended up replacing 2 sensors after I replaced the LF and the RR would not train . BTW I will buy your old sensors when you get them out.
What do you pay for them? Three of them still work.......for awhile Send me a private message with that and your e mail address. Jim
