spacers?
Old May 15, 2008 | 01:14 AM
TKT-MKR's Avatar
TKT-MKR
Default spacers?
Will putting spacers say 1/4 or 1/2 inch effect the car any or cause it to become weaker in the suspension and break easier?
basically is there any down side to wheel spacers?
Old May 15, 2008 | 01:20 AM
clayton1's Avatar
clayton1
Banned Scam/Spammer
I believe they will have some affect on certain wheel alignment angles.
Old May 15, 2008 | 02:36 AM
TKT-MKR's Avatar
TKT-MKR
so other then an alignment, will it cause anything bad to the suspension, or the hubs or the axles or the anything like that?
Old May 15, 2008 | 03:35 AM
jdmvette's Avatar
jdmvette
Night Owl for life
i've ran mine with them for about 1.5 years now with no ill effects.
Old May 15, 2008 | 07:22 AM
EVIL_C5's Avatar
EVIL_C5
Uber Waxer
Cruise-In 8-9-10-11 Veteran
CI 9, 10 & 11 Car Show Winner
St. Jude Donor '08-'10
hub centric lug nuts to keep the wheel centered on the hub
Old May 15, 2008 | 08:54 AM
TKT-MKR's Avatar
TKT-MKR
where is the best place to get them?
also i figured to get the ones that bolt on and have there on bolts that you then bolt your wheels to
know any place to get these?
Old May 15, 2008 | 08:59 AM
AU N EGL's Avatar
AU N EGL
I use 3/8" spacer with no problems. Do need Longer ARP studs and harden open ended lug nuts
Old May 15, 2008 | 12:46 PM
TKT-MKR's Avatar
TKT-MKR
so basically the census is that there is no downfall to using spacers?
Old May 15, 2008 | 12:50 PM
Lancer033's Avatar
Lancer033
as long as your studs are long enough for the lugnuts to get a good bite and the hub still holds the weight of the wheel or the spacer has it's own hub built in, your good to go.
Old May 15, 2008 | 01:17 PM
Kale's Avatar
Kale
Well, there is if your goal is to stick the wheels outside of the wheel well.
Old May 15, 2008 | 02:49 PM
AU N EGL's Avatar
AU N EGL
Easy answer.
Flairs 3/4" wider then stock.
Old May 15, 2008 | 05:52 PM
jdmvette's Avatar
jdmvette
Night Owl for life
or 2" wider than stock.
Old May 15, 2008 | 06:25 PM
TKT-MKR's Avatar
TKT-MKR
well i want my wheels to be even with the top of the wheel well.
it doesnt look like it will take much to do it
like i mentioned 1/4 inch to 1/2 inch
so does anyone know where is a good place to get spacers or spacers with hub and lug built in at?
Old May 15, 2008 | 07:03 PM
c3spdrcr20's Avatar
c3spdrcr20
Old May 15, 2008 | 08:40 PM
jdmvette's Avatar
jdmvette
Night Owl for life
from what i've seen you cannot get the adapters with the studs built into them with a thickness of < 1".
they're all 1" or thicker.
the ones with the studs built in are referred to as "adapters" and the ones without are "spacers".
if you need something that thin just go look on ebay for "wheel spacer" & whatever thickness you want and "5x4 3/4" which is what our wheels use.
i recently picked up these 1/8" aluminum spacers from ebay.
you can see the multiple holes which some spacers have. these holes allow different wheel stud sizes to be used. (e.g. 5x4 3/4; 5x4 1/2; 5x5)
Old May 15, 2008 | 09:42 PM
clayton1's Avatar
clayton1
Banned Scam/Spammer
You should get an alignment done before you put the spacers on and get one after you put the spacers on, Just for argument sake
If you put spacers, or different offset rims you will be changing the scrub radius, making it more positive-in the case of spacers. (Scrub= the intersecting of the center line of the wheel(camber line) and the SAI, in relation to the mating surface of tire and road.)
And a change in scrub radius has an effect on the Toe settings.
I believe a more positive Scrub radius on a rear wheel drive will give it more toe-out.
I could be wrong though.....
Old May 16, 2008 | 04:59 PM
c3spdrcr20's Avatar
c3spdrcr20
Ouch. That made my head hurt.
To spacers?
Old May 16, 2008 | 05:32 PM
AU N EGL's Avatar
AU N EGL
And that is why when you change wheels one needs to learn how to do your own alignments.
String, Calculator, Level, triangle, two tape measures HARDBAR toe plates. and a little time.
Old May 16, 2008 | 09:51 PM
uniqvett's Avatar
uniqvett
Is there any info on doing your own alignment.
Old May 17, 2008 | 03:03 AM
clayton1's Avatar
clayton1
Banned Scam/Spammer
And the specs!!!
Hey Uniqvett- My teacher gave us a pretty good website-check it out....http://www.familycar.com/Classroom/ scroll down and click on wheel alignment.
