Vararam - Good first mod?
Old May 16, 2008 | 10:44 AM
Berger6696's Avatar
Berger6696
Default Vararam - Good first mod?
How much performance/HP does this add? For a n00b, is this an easy mod? Anything else that needs or should be done before this? I've got a bone stock 97 with 66K on it.
Old May 16, 2008 | 11:01 AM
DPG's Avatar
DPG
St. Jude Donor '06
not sure on hp gain but people have shaved .2 tenths of 1/4 times and it brings in cool outside air.
not too easy of a mod, but read cajundude's instructions and the install will be much easier.
after you are done, disconnect the battery for about 20 min, then connect it back up and drive the car for about 30 min to relearn the idle.
Old May 16, 2008 | 11:09 AM
Tikiman12's Avatar
Tikiman12
TOTALLY worth it. vararam rates it at a 40hp gain. i dont have any dyno #'s to prove it but its close. you'll love it. and its a fun do it your self project
Old May 16, 2008 | 11:13 AM
Polar Jet's Avatar
Polar Jet
Aside from an exhaust plate, a set of rear fascia letters and a center console emblem, it was my first real mod. Definately a good place to start. It was worth the money.
Old May 16, 2008 | 11:14 AM
kerryt1's Avatar
kerryt1
It'll be harder to install that an open element like the Halltech, but I like the idea behind it. My car has one.
Old May 16, 2008 | 11:25 AM
GMANS C5's Avatar
GMANS C5
Mine was waiting on my porch when I got home yesterday. I might be putting in in this weekend...
Berger6696's Avatar
Berger6696
What kind of time am I looking at here? Me (inexperienced) and a buddy (experienced, but not with vettes).
Old May 16, 2008 | 11:34 AM
Berger6696's Avatar
Berger6696
Thanks guys, bought it. Any further tips are appreciated.
Old May 16, 2008 | 11:35 AM
NotScared's Avatar
NotScared
St. Jude Donor '23, '25
Putting mine in this weekend (time permitting). I've been told to expect anywhere from 1-4 hours, depending upon how it "lines" up with my specific vehicle. Be sure to use the Cajundude's install directions.
http://www.cajundude.com/c5techhome.htm
Andrew
Old May 16, 2008 | 11:39 AM
Berger6696's Avatar
Berger6696
Andrew
Awesome, thanks!
Old May 16, 2008 | 11:40 AM
DPG's Avatar
DPG
St. Jude Donor '06
Andrew
there ya go. grab some beers and take your time. yes it takes more time than the open element filter, but so worth it
Old May 16, 2008 | 11:43 AM
peter pan's Avatar
peter pan
Life Time NCM #2196
Do it as bringing in more air is a good thing and do the hood seal at the same time you will gain even more HP
Old May 16, 2008 | 11:50 AM
Berger6696's Avatar
Berger6696
Old May 16, 2008 | 12:39 PM
moserbe's Avatar
moserbe
Good mod, mine has been on for a year now.
Old May 16, 2008 | 12:46 PM
wildbadbill's Avatar
wildbadbill
I installed mine two days ego and it took 1.5 hrs-but I work a lot on my toys.Not complicated but follow the instruction.Make sure you can lift the car at least a foot since most of your work is under the nose.I used a jack under the middle of crossmember and lifted the whole front.
Good luck...
Old May 16, 2008 | 01:04 PM
superstreet's Avatar
superstreet
St. Jude Donor '10
Once you install the Vararam, you're getting plenty of air in so the next mod you need is B & B Bullet exhaust or equivalent.
Old May 16, 2008 | 01:07 PM
Stonecutter908's Avatar
Stonecutter908
Good luck...
Did you use supplied instructions or Cajun's or a combo? I just read through Cajun's and am now intimidated by this mod even though I prob shouldn't be.
To Vararam - Good first mod?
Berger6696's Avatar
Berger6696
Good luck...
Oops, didn't think about that.
Old May 16, 2008 | 01:45 PM
candacedianne's Avatar
candacedianne
I think my husband said its an 18 HP gain? Could be wrong, I am going off of memory. It's a great first mod! It was the first mod we did to our Z! Good luck!
Here is their website:
http://www.vararam.com/b2.html
Old May 16, 2008 | 01:54 PM
glerma's Avatar
glerma
St. Jude Donor '05
40 HP seems very lofty. I wonder if that claim is on an otherwise stock motor? I remember when I used to have Mustangs... you could find dyno numbers for just about every mod.. They're not so easy to find for 'Vette. Does anyone have Dyno numbers (not from the manufacturer) for this unit?
