[Z06] Got an allignment done...
FRONT
Caster Left = 7.1
Right = 7.7
Camber Left = -0.9
Right = -1.2
Toe Left = 0.0
Right = 0.0
Total = 0.0
REAR
Camber Left = -0.5
Right = -1.1
Toe Left = 0.00
Right = -0.10
Total = -0.10
Thrust Angle = 0.1
What do you guys think...
It's a crap job at an alignment that's for sure, either the guy was a complete idiot or just plain didn't care about the job. Take it back and have them set camber, caster and toe to the factory spec - or get your money back and go find a good shop...
Savior1974--Take it back and have them do it again. The car's fully adjustable and they wasted your time and money by only setting the toe.
Left Front:.................................Right Front:
Camber: - 0.16 degrees............Camber: - 0.17 degrees
Caster: 7.29 degrees..................Caster: 7.31 degrees
Toe: 0.02 degrees in.................Toe: 0.02 degrees in
............................Cross Camber: 0.01 degrees
............................Cross Caster: - 0.01 degrees
............................Total Toe: 0.04 degrees in
Left Rear:..................................Right Rear:
Camber: -0.21 degrees................Camber: - 0.23 degrees
Toe: 0.02 degrees out.................Toe: 0.01 degrees out
...........................Total Toe: 0.03 degees out
...........................Thrust Angle: 0.00 degrees
Also, you want a slight amount of toe out in the rear, so when you are driving down the road and applying power the rear wheels are pulled to zero toe in. That rear total toe of 0.20 degrees that you have will kill your rear tire wear.
After two years of hard driving, about 6 to 7 track days a season, and many miles of twisty road driving, my Michelin PS2s are wearing evenly and still have lots of tread.
A good alignment makes a great deal of difference. Take you Z back and have him do it right.
FRONT
Caster Left = 7.1
Right = 7.7
Camber Left = -0.9
Right = -1.2
Toe Left = 0.0
Right = 0.0
Total = 0.0
REAR
Camber Left = -0.5
Right = -1.1
Toe Left = 0.00
Right = -0.10
Total = -0.10
Thrust Angle = 0.1
FRONT
Caster Left = 7.1
Right = 7.7
Camber Left = -0.9
Right = -1.2
Toe Left = 0.0
Right = 0.0
Total = 0.0
REAR
Camber Left = -0.5
Right = -1.1
Toe Left = 0.00
Right = -0.10
Total = -0.10
Thrust Angle = 0.1
Also, the complete LACK of toe in the front would make it kinda skittish (I think)
TAKE it back, find the factory specs and have them match them to the number, BOTH SIDES!!!
I hate lazy wrench turners....
-Ed
I'd think that neutral toe in front, and just a bit toe in in the back would be optimal. Under power, the rear will squat and bring the wheels back to true. If you toe out the rear, it'll toe out MORE under thrust, and tend to oversteer more.
There's a decent argument for neutral toe in front, since when you brake, it'll toe out slightly, making turns easier. The tradeoff is that under power, it'll understeer a bit, but that's safe for a street car. Track cars... are a different thread.
Max caster == max straight line stability, so that's a no brainer.
And for heaven's sake, take your car back and have them do the job right.
I am on my third C5Z06----and only autocross my 04 C5Z06...
HERE IS THE ALIGNMENT SCOOP......
0 toe in the front is fine.....and little toe out (negitive # like -.03 per side is fine and will deal with any corner entry understeer)
That guy that has no negitive camber (-.17)------his car corners like crap--------the car stock spec is like .7 neg front .5 neg rear.......I max my camber front and rear and don't much consider caster as long as the caster is even right to left. (max stock is like about -2.0 front and like -1.2 rear.
In the rear for stability you want like .08 to .12 each side toe in which is a positive number, and will make the car stable and put down power well.
Try to get numbers equal right to left side. Uneven Caster will cause a slight pull---to the lesser side (i think ?)...
Good luck
FRONT caster must be EQUAL on both sides
Caster Left = 7.1
Right = 7.7
Camber Left = -0.9 move this out to -1.2* also
Right = -1.2
Toe Left = 0.0 1/16" OUT
Right = 0.01/16" OUT
Total = 0.0 doesn't mean squat - toe should be measured in inches not degrees
REAR
Camber Left = -0.5 more is needed -1.0*
Right = -1.1 -1.0* and equal
Toe Left = 0.00 1/16" IN
Right = -0.10 1/16' IN
Total = -0.10
Thrust Angle = 0.1
Good Luck
Also in my experience toe in will give you more stability at speed but make the car not turn is quickly and nimbly - toe out can make the car darty and wander at speed, but will make it very responsive when going into a corner... I prefer toe in myself for a car that's going to see street duty...
Also if they'll let ya, sit in the car while they set it up - you'll be amazed at how much a 180lb person in the drivers seat will change alignment specs...
I would think you'd want a bit of front toe IN. Entering a corner, the OUSIDE tire is more heavily loaded, and being toed out steering OUT of the turn, you'd actually increase your understeer gradient at turn in. Plus, under forward longitudinal load, toe out would just get worse.
Also, can you explain why you say degrees are meaningless for measuring toe? Hunter and other commercial alignment systems measure in degrees. You have to do some math and careful measurement to figure it our on your typical DIY set-up, but the measurement is just as valid.
I agree with wanting a bit of toe IN in the rear. Rear toe OUT will reduce understeer, but can also makes the steering non-linear and unpredictable. There maybe some conditions or set-ups where you'd need static toe out, but I doubt the OP does.
Here is one of the best explanations why... http://www.davidfarmerstuff.com/Toe-Ackerman.pdf
Hunter alignment machines are more off then ppl think. 2 psi difference in tire pressure change your alignemt, Not having your body wt in the drivers seat during the alignment changes the alignment too.
( Make sure the tires are at OPPORTAING temp, not 32 psi cold temp, and YOU ARE SITTING IN THE DRIVERS SEAT ( or an equivent wt) when the alignment is done.
Great alignments are more to do with the tech then any machine. If the tech can not make those calculations from degrees to Inches, find a different tech.
Why do we say INCHES and Not DEGREES? Most measurements are toe done in inches and camber measurements are done in degrees. This makes it very easy to separate the two out.
Plus anyone worth their alignment skill can do an alignment by hand, with string, two tape measures, toe plates,Smart Camber device, paper, pen and calculator.
