18" or 19" wheels
Old May 30, 2008 | 07:14 PM
wildbadbill's Avatar
wildbadbill
Default 18" or 19" wheels
I've seen some pics here of C5's with 18 or 19 wheels on front and back.What's involved in installing the same size front and back?
thanks
Old May 30, 2008 | 07:24 PM
PostShawn's Avatar
PostShawn
You have to have the tire heights at different sizes so it doesn't confuse the traction control. What different heights I can't remember. I know it's been mentioned before. If you buy from an approved forum vendor then they usually know the common setups and sizes needed. I bought my tires from TomZ Wheels. I told him the sizes of the wheels I was getting and he recommended tire sizes. I couldn't be happier with what I got.
Old May 30, 2008 | 07:31 PM
AU N EGL's Avatar
AU N EGL
as long as the rear tire is slightly larger then the front then TC/ AH does not get confused.
I have run identical sizes on all four corners with out problems untill a high speed sweeper, then the TC kicked in and I thought "WTF is going ON?" OH hit the TC OFF button and no problems
go with 18s all around. They look great
Old May 30, 2008 | 07:47 PM
wildbadbill
what size tires with the 18" ?
Old May 31, 2008 | 12:53 AM
jdmvette's Avatar
jdmvette
Night Owl for life
i ran 18/18 for a while. once i got 18/19 i realized how much i missed the staggered look.
Old May 31, 2008 | 07:13 AM
AU N EGL's Avatar
AU N EGL
What size rims do you have or what do you want?
My ideal choice for a C5 street use would be
18x10 front with 18x285/35
18x11 rear with 18x305/35 rear
any thing wider just wallows at slow speeds
My street set up is 18x10 with 18x275/35 front and 18x12 with 18x335/30 rear. 335 rear is too wide for street use
track use is 18x12 with 18x305/30 or 18x315/30 front and 18x13 with 18x335/30 or 18x345/35 rear, at slow speeds the car feels like a pig in the mud.
Old May 31, 2008 | 09:31 AM
JCSZ51's Avatar
JCSZ51
Cruise-In IX Veteran
I run 18" mags front and rear
275/35 18 front
275/40 18 rear
Overal diameter is exactly the same as factory.
Old May 31, 2008 | 09:39 AM
FrankTank's Avatar
FrankTank
CI 7-8-9-11 Veteran
St. Jude Donor '06-'10, '13
I am running 19's all the way around
19x10 front with 275s
and 19x11 in the rear with 295s
ccw wheels no issues like said above with traction control/AH as long as fronts are a bit smaller than rears.
Old May 31, 2008 | 01:01 PM
Chemdawg99's Avatar
Chemdawg99
St. Jude Donor '12 thru '21
This is what makes the C5 a beautiful car to look at from every angle, IMHO.
An 18"/19" set up should not pose any issues for you and you keep the sexy staggered look
Old May 31, 2008 | 01:07 PM
DeeGee's Avatar
DeeGee
I was just re-reading "All Corvettes are Red"
Its interestiing finding out the background as to why the C5 ended up with 17/18s.
I'll leave that one hanging.
Old May 31, 2008 | 01:09 PM
AZZ-KIKR's Avatar
AZZ-KIKR
I like the looks of my 19/20's.
Old May 31, 2008 | 01:28 PM
Chemdawg99's Avatar
Chemdawg99
Interesting indeed
Old May 31, 2008 | 02:27 PM
AU N EGL's Avatar
AU N EGL
Purely cosmetics...
Old May 31, 2008 | 03:37 PM
FrankTank's Avatar
FrankTank
CI 7-8-9-11 Veteran
Purely cosmetics...
Its also interesting how they decided to make the stock LS1 make 350HP
Old May 31, 2008 | 03:46 PM
Nihilation's Avatar
Nihilation
I run 18x9.5's all around with 275/35's F and 275/40's R which give the OE spec heights. Soon I'll be running the badass Dunlop SS Z1's in 275/35's all around.
Old May 31, 2008 | 03:50 PM
Chemdawg99's Avatar
Chemdawg99
Because, unless you are putting the car on the drag strip, 350HP is all you need, IMHO
Old May 31, 2008 | 03:52 PM
DeeGee's Avatar
DeeGee
Default The Problem the Designers Faced
This doesn't quite answer the OPs original question but interesting all the same.
I've para phrased this from the book.
John Cafaro, the design guru for the C5 was a big tire advocate. He wanted bigger tires at the rear to give the car the racy nose down look. He also wanted wide tires at the rear to give the rear aspect the “Don’t Mess With Me” appeal. Dave Hill the Chief Engineer for the C5, was faced with a clay model that had 17s up front and 19s in the rear. The catch was that tires were one of the main aspects that would dictate ride and handling for the new model both of which needed improving over the C4.
The challenge they both faced was to get the C5 down to the coefficient of drag target of 0.29. The models were running 0.32 to 0.34 in the wind tunnel which was way too high. The combination of poor airflow nd a wide butt because of the fat tires was killing it.
One of the key areas was aerodynamic flow under the car. (Those of you who take off the air dams take note). The engineers were suggesting adding belly pans but these were adding weight and cost. The designers wanted to shorten the car cutting cost and mass. Their solution was a flat underside to the front fascia.
Dave Hill’s solution was to shave the side glass by ½” between the A pillar and the B pillar (windscreen and rear pillar) to stop aerodynamic break away. Romberg, another engineer pointed out that the rear width was the biggest factor and they needed to make the car trimmer in width at the rear.
The crunch was Dave Hill wanted 17s all round even though he knew that handling would deteriorate. Cafaro was hard over on the larger rears for design appeal. He played the handling card knowing the engineers would be unable to argue the fact.
Bottom line was the tires were a key part of a complicted design decision involving anumber of factors. In the end the compromise was 17s front 18s rear to give a balance between handling and looks.
Maybe E-T can add some more insight
To 18" or 19" wheels
Old May 31, 2008 | 03:56 PM
Chemdawg99's Avatar
Chemdawg99
Nice post
Old May 31, 2008 | 04:01 PM
STL94LT1's Avatar
STL94LT1
So do I!!!
Old May 31, 2008 | 04:15 PM
wildbadbill
can you really see the rubber side is higher in he rear?
the rubber is 13.75 mm higher in the rear which is approx. 1/2"
