No dash lights or tail lights
Old Jun 4, 2008 | 10:44 AM
BeckyBall's Avatar
BeckyBall
5th Gear
Default No dash lights or tail lights
I have a 99 corvette that I am having problems with. No dash lights or tail lights. Brake lights work - head lights work.
Any suggestions?
Old Jun 4, 2008 | 10:45 AM
tellefan's Avatar
tellefan
A blown fuse.
Old Jun 4, 2008 | 10:47 AM
DeeGee's Avatar
DeeGee
Its unlikely to be the fuse as they are on seperate circuits: Tail lights fuse #6 (park) #8 (stop) IPC #19 & #25 in the footwell.
Before you try anything more complicted there's a strong possibility it could be either the hazard warning switch or the headlight switch on the stalk.
First off try recycling the hazard switch a number of times quite firmly and see if they come back. A lot of the lighting functions route through that switch and they're notoriously unreliable.
If that doesnt work try the same on the headlight multi function switch. if we can tie down the problem to one of them theres a DIY fix.
Old Jun 4, 2008 | 10:50 AM
BeckyBall's Avatar
BeckyBall
5th Gear
Thanks ~ thats a good place to start.
Of course the first thing I checked was the fuse. That would have been way too easy!
Old Jun 4, 2008 | 12:25 PM
tellefan's Avatar
tellefan
Sorry
Old Jun 5, 2008 | 03:38 PM
BeckyBall's Avatar
BeckyBall
5th Gear
I tried all of the suggestions that you gave with no success. Any other thoughts to share?
Old Jun 5, 2008 | 04:41 PM
BeckyBall's Avatar
BeckyBall
5th Gear
I have tried all of the suggestions listed below. Any additional thoughts? The dash lights do work when the car is not running (when you first get in & close the door) but when you start the car they do go off.
Old Jun 5, 2008 | 04:48 PM
wildbadbill's Avatar
wildbadbill
don't know if you have a volt meter,but I'd check if you have power to the above mentioned fuses when the ignition switch is ON.If not you may have bad contacts in the switch...
Old Jun 5, 2008 | 04:50 PM
MyVetteDream's Avatar
MyVetteDream
From: HOW FAST WAS I GOING OFFICER? Los Angeles Hating GM Dealership Service Dept.'s Since Sept. 2004
St. Jude Donor '04-'05-'06-'07
When was the last time they worked?
I would check the #2 fuse in the footwell. It's an overload fuse ---
Old Jun 5, 2008 | 05:50 PM
BeckyBall's Avatar
BeckyBall
5th Gear
Thanks everyone for the suggestions - off to try them. Wish me luck
Old Jun 5, 2008 | 06:34 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Fuse #6 Passenger Footwell (10A)
Old Jun 5, 2008 | 06:43 PM
SSWEET's Avatar
SSWEET
This recently happened to me...It was the multi function headlight stalk. You can buy new or used on that auction site...There is a good write up on the forum on replacing or repairing....
Old Jun 5, 2008 | 06:45 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
It's either the fuse or switch. I would check it out with a electrical tester first to confirm switch or power problem.
Old Jun 5, 2008 | 06:55 PM
c5streak's Avatar
c5streak
I'm betting on the switch too. Here's a couple of threads about the same problem and a fix for it, for your reading pleasure.
http://forums.corvetteforum.com/show....php?t=1826359
http://forums.corvetteforum.com/show....php?t=2032925
Old Jun 5, 2008 | 07:01 PM
C5 4 ME's Avatar
C5 4 ME
I had a problem where my instrument cluster would not light up but the gauges all worked. I replaced the multifunction switch and the problem persisted. I finally replaced the instrument cluster which fixed the problem. Hope this helps.
Old Jun 7, 2008 | 03:04 AM
DeeGee's Avatar
DeeGee
Any luck with #6?
Old Jun 7, 2008 | 06:43 AM
65GGvert's Avatar
65GGvert
Not sure why you'd have to have the ignition switch on, those two functions work with or without the ignition on. The fuses should have power all the time.
To No dash lights or tail lights
