Are the Headlights Adjustable?
. Help guys
.-Alex
Aiming Stock Headlights
Preparation
Chose a white wall to project the lights onto
Mark a vertical centreline on the screen in line with the center of the car (black tape?)
(look over the roof of the car to get the line)
Measure the height from the floor to the center of the headlight capsule
Mark a horizontal aiming line on the screen
Measure the distance between the centreline of the right headlight module and the center of the left headlight module.
Position the vertical tapes this distance to the right and left of the screen centreline
Lubricate the adjustment screws before adjusting
Adjustments
Raise the hood
Raise the headlights
Remove the headlamp adjustment screw plug
Turn on the low beam headlights and block the light from projecting onto the screen from the passenger headlight
Check the horizontal aim
Adjust the horizontal aim adjusting screw to align the left edge of the high intensity zone with the headlight vertical centreline
The left edge of the beam should lie within 4” to the left and 4” to the right
of the vertical centreline.
Check the vertical aim
Adjust the vertical aim adjusting screw to align the top edge of the high intensity zone with the headlight horizontal centreline
The left edge of the beam should lie within 2” above and 2.5” below the lamp horizontal centreline.
Reinstall the headlamp adjustment screw plug
Repeat for the other headlight
Turn off the lights and close the hood
This is the pattern you're looking for
You might want to lube the adjustment rod
Take a look at this great write up from Junkman for a problem to avoid
http://forums.corvetteforum.com/show...ght=golden+rod
QUOTE]
Will WD40 work okay, or do I need some other lubricant?
-Alex
The higher and more left you go, the greater the risk of blinding an oncoming driver.
-Alex
Prior to adjusting them make sure that you Lube the adjusters WELL. The metal rods used for adjustment will snap off in a heartbeat if the gearing is the slightest bit tight. I fooled with mine for two hours after bathing the stuck adjusters in PB Blaster. Just worked the rods a little at a time. Once they start to move, move them gently.
