E-85
Old Jun 17, 2008 | 05:20 PM
my6thvette's Avatar
my6thvette
Originally Posted by DPG
once the demand really begins to go up, farmers will just grow more corn, its that simple. we have more corn than we know what to do with and like said before, there is diff corn for diff uses.
If "we have more corn than we know what to do with", why has the price more than doubled. Ever hear of the law of supply and demand? Sure the farmers can grow more corn but at the expense of other crops. It has been calculated that if we were able to convert the entire surface of the United States into a giant corn field, we could not grow enough corn to replace the amount of gasoline currently used.
The real problem with ethanol is that it takes about the same amount of energy to produce it as is provided by burning it as a motor fuel.
Old Jun 17, 2008 | 05:24 PM
Corvette Don's Avatar
Corvette Don
and in the end you are going to burn more therefore the price works out to be almost the same as if you were to buy normal gas, E85 is great for high compression and boosted cars (10.9+) due to the high octane content.
Old Jun 18, 2008 | 01:51 AM
cor28vettes's Avatar
cor28vettes
Originally Posted by jedblanks
maybe off topic, but what about the C6s? At least the late model ones?
C6 Owners manual says it's a no no
Old Jun 18, 2008 | 09:04 AM
Vega$Vette's Avatar
Vega$Vette
Originally Posted by Professorsc5
I have a flex fuel Chevy Tahoe. You can come up with all the excuses you want and it all BS. Yes may its not as efficient as gas, but when I run E85, I get maybe 19 MPG instead of 20 or 21 MPG but at 105 octane I never use passing gear. Forget the tortias and the shortage of corn, a few years back they were paying farmers in the US not to grow corn more BS. Also in California regular gas is $4.47 at Costco, more at other stations. In fact I paid $4.77 for Chevron premium last Tuesday and that was cheap for 91 octane. Now if you can find it here in Calif. E85 is $3.59 and that is 105 octane. I enjoy my Vert and have given some serious thaught into reprogramming my Vert to run on E85 so I can afford to continue driving it. Also you do not need corn to make E85 you can use some types of grass or sawdust or even trash.
E85 is only 20 cents a gallon less then regular 87 NOT 88 cents.
My 07 flex fuel Avalanche dropped from 16.9 mpg to 12.7 mpg the 1st and last time I ran E85.
