Gas gauge
Old Jun 18, 2008 | 01:52 PM
slick 50's Avatar
slick 50
Cruising
Default Gas gauge
Yesterday, I was 30 minutes into an hour drive with 1/2 tank of gas. At once, the gas gauge goes to empty, the red light came on the dash and said, check gauges and the screen said fuel low. I filled up. The gauge never got off of empty.
Has anyone experience this? Was it the gauge or fuse or electrical problem?
Thanks,
Old Jun 18, 2008 | 01:53 PM
james_earl's Avatar
james_earl
Do a search, many many many others have had this same problem.
Techron FTW
Old Jun 18, 2008 | 02:19 PM
VinnyT's Avatar
VinnyT
Faulty gas gauge
If you have bad gas, the fuel sender can be affected by the high sulfur content in the fuel, and cause the gauge to read empty. They car will still operate normally, and the gas gauge will work again if you use better gas, and will usually start again when you restart the car. It's just better to use good gas. Some people have had luck with running fuel filter cleaners thru the gas tank. New fuel senders sometimes fixes this problem.
Also use a bottle of Techron when filling up. Use Premium fuel from a Top Tier station(Chevron, Texaco, etc)
Old Jun 18, 2008 | 02:22 PM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
As stated before, One of the best things you can do for your fuel system is use Chevron fuel, It has corrected a lot of the members gauge that had the same trouble as you do. If you don't have Chevron in your area just run a bottle of the Chevron fuel additive with a fill up a number of times.
Old Jun 18, 2008 | 02:24 PM
MagRedConv's Avatar
MagRedConv
Do a search as suggest above. This has been "discussed" numerous times.
Old Jun 18, 2008 | 02:32 PM
C5 4 ME's Avatar
C5 4 ME
I had a similar problem and was advised to try Mobil premium fuel and the problem went away. Hope this helps.
Old Jun 18, 2008 | 03:35 PM
slick 50's Avatar
slick 50
Cruising
Thanks, we don't have Chevron but I'll keep looking. I will try some fuel additive as well.
Hope you are having a great day in beautiful Rocky MT.
Old Jun 18, 2008 | 03:39 PM
DeeGee's Avatar
DeeGee
A couple bottles of Techron will fix it. Common problem
Old Jun 18, 2008 | 03:40 PM
Optimus_C5's Avatar
Optimus_C5
From: If opportunity doesn't knock, build a door. South West Florida / Livin' The Dream
St. Jude Donor '12
You can buy Techron at most major auto parts stores. Techron is the additive in Chevron that helps with this problem.
I get the problem a couple of times and one fill-up with Chevron and about 25 miles of driving and it starts working again. Go figure?
Old Jun 18, 2008 | 03:43 PM
slvr bulit's Avatar
slvr bulit
It happened to me, I ran a big bottle of Techron fuel cleaner through it and that helped out alot. Also check your codes see if you have a p1432. If so reset it and your fuel gauge will work again. Good luck
Old Jun 18, 2008 | 06:15 PM
jrose7004's Avatar
jrose7004
Run Techron thru it a couple of times a year and it will help that problem!
Old Jun 26, 2008 | 10:34 PM
okbkvette's Avatar
okbkvette
Default same problem today
man, happened to me today, same deal, gauge dropped to "e", while I had a half tank, and it's bounced around full/empty, full/empty the rest of the day. Funny, I just bought some of that techron additive few days ago and was going to put it in next fill up to try and prevent, and there you go.
I'll give the techron a try.
BUT, if that does not work, do they have to drop the tank to "check" or replace the sensors? Is replacing that part of just replacing the fuel pump/filter assembly?
Old Jun 26, 2008 | 10:37 PM
Muddbug1's Avatar
Muddbug1
St. Jude Donor '08
I had this same thing happen to me. 1 bottle of Techron and about 50 miles later everything was working fine. Now I put in a bottle about every 4th fill up.
Mudd
Old Jun 26, 2008 | 11:10 PM
cbug's Avatar
cbug
i used the seafoam
Old Jun 27, 2008 | 01:21 AM
oyealiz's Avatar
oyealiz
2022 C8 of the Year Finalist - Unmodified
CI 3-4-5-6-7-8-9-10 Veteran
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'16
I always reset the trip when I get a new tank of gas. Always. I know about how far I can go, so if the fuel gauge messes up (for the xxx time ), I don't worry.
Now...when my c6 did it a couple of weeks ago....
And, no, I'm not kidding.
Old Jun 27, 2008 | 01:54 AM
Z06ster's Avatar
Z06ster
Ultimately, it is the sensor that goes bad. Sometimes it is the sensor in one of the tanks, other times, it is the sensor in both tanks. I know for one of the tanks, just the sensor can be replaced, but on the other side, you are forced to replace the entire sending unit. The dealer can give you the proper diagnosis for a little under $150.
Here's what happens to the sensor. Note the black smearing. The traces are supposed to be shiny throughout...
Old Jun 30, 2008 | 02:51 PM
MotleyDrew's Avatar
MotleyDrew
Mine statrted doing this now as well I will try the additive first as I am not in the mood for dropping the tank !
To Gas gauge
Old Jun 30, 2008 | 02:58 PM
bucwheat's Avatar
bucwheat
Not always! may need to replace the sensors .
Old Jun 30, 2008 | 07:11 PM
doug doo wop's Avatar
doug doo wop
I had the problem once and changed to chevron or texaco with techron and the problem went away. Techron keeps the sensor clean.
Old Jun 30, 2008 | 10:13 PM
You can usually find a bottle of Techron at most auto parts stores. Might even find it at Wal-Mart.
