Vanity Mirror
Old Jun 20, 2008 | 05:42 PM
midlifetoy1's Avatar
midlifetoy1
Default Vanity Mirror
Just noticed that the vanity mirror on the passenger side has partially detached from the sunvisor. Now it is just attached at the bottom. What gives??? No one even uses the thing!! How is the mirror attached. Or will I need to purchase another?
Old Jun 20, 2008 | 06:08 PM
Purdone's Avatar
Purdone
You've got to be kidding me! Mine came unattached at the top last night! Mine happened when I was doing about 75 on the highway. All of a sudden there was a loud crack! and it was dangling. I threw up in my mouth a little.
Old Jun 20, 2008 | 06:09 PM
rpm462's Avatar
rpm462
Check this thread out, post #15, there's a fix for them.
http://forums.corvetteforum.com/show....php?t=1817090
Old Jun 20, 2008 | 06:46 PM
midlifetoy1
Default Sun Visor
Thanx!!!!! Thats just what I'll be doing in the morning. By the way, is there a way that I can bookmark that thread for future reference. Saw a lot of information I may need in the future.
Old Jun 20, 2008 | 10:56 PM
Blueheeler's Avatar
Blueheeler
Ahhh almost good point..My problem with my mirrors is that the lid i guess you could call it at times doesn't shut all the way. I noticed this at night driving down the road and i can see the light shining thru the visor. If i were to hold it shut of course it goes off....I'm sure i could tape it shut to hold it down....but that has got to be a better way..??
Old Jun 20, 2008 | 11:16 PM
bestvettever's Avatar
bestvettever
Default Fix Vanity Mirror
Hi, thats a good fix. I found industrial strength Velcro tape works real well, and if needed you can remove the assembly to repair it.
Good Luck
Old Jun 21, 2008 | 01:58 AM
DeeGee's Avatar
DeeGee
Here's the zip tie mod that I posted
Refix Vanity Mirrors
Pull the mirror away from the housing gently. Stick a piece of 3M double sided tape along the inside edge of the top of the mirror between the two holes in the visor.
Thread a small zip tie through each hole from the back and outside of the hole, with the “head” of the tie located in the large rectangular recess. Pull the tail of the zip tie towards you and thread from inside to out through the hole in the locating pin. Push the tail through the head loosely at first.
Use needle nosed pliers (holding the tail) and a precision screwdriver (pushed against the head) to tighten the zip ties. Be very careful when pulling the ties tight not to pinch the lighting wires which run through the same hole. Once tight, snip the spare tail of the tie but carefully so as not to snip the electrical wires.
Push the mirror back into its housing and press firmly against the double sided tape.
Should be good as new.
Old Jun 21, 2008 | 03:07 AM
Chicago1's Avatar
Chicago1
Both mine are dangling broke from the whole assembly hanging by the wiring from the light. Time to fix tommorow
Old Jun 21, 2008 | 12:07 PM
Purdone's Avatar
Purdone
Near the top of every thread is a "Thread Tools". If you click on that you get a drop down, and one of your options is to Subscribe to this thread. You can then access the threads you have subsribed to via the User CP at the top of the forum.
Old Jun 21, 2008 | 05:25 PM
midlifetoy1
Many Thanx to both DeeGee & Purdone..2 more of my many questions answered.
To Vanity Mirror
