Launching Tips?
Old Jun 29, 2008 | 02:13 AM
azZ06Mike's Avatar
azZ06Mike
St. Jude Donor '11
Default Launching Tips?
i have done three launches on my MT ET Streets at 18 psi. I slipped the clutch the first time at 4000 rpm and bogged. Second i dumped the clutch at 4500 rpm light bog and got a 1.7 60ft! Third slipped at 5000 rpm and big bog!
What are you guys finding that works?
i have rpm level5 tranny harden shafts and dte brace so it can handle a launch along with a textrilia oz700 clutch!
Thanks in advance!
Old Jul 3, 2008 | 11:22 PM
shawn copella's Avatar
shawn copella
Mike i posted the same questions with no answers. Good luck, I'm having a terrible time trying to get the car to launch.I love my level 5 tranny and Hurst shifter with soft springs
Old Jul 3, 2008 | 11:29 PM
lil vette's Avatar
lil vette
TC off?
Old Jul 4, 2008 | 01:31 AM
itzza427's Avatar
itzza427
Originally Posted by lil vette
TC off?
Even with drag radials 4000 seems like it should be enough to get you off the line hard! I'd try maybe 20 lbs in the tires as well as putting in in competitive driving mode.(Just in case you don't know ,press and hold your TC button and hold it for 5 seconds after you see traction control off,and it will display Competitive driving mode) Then you should get some spin!
Old Jul 4, 2008 | 01:50 AM
Juicdta's Avatar
Juicdta
c5's you need to rev it almost to redline and slip the hell out of the clutch. look up videos and watch them. non of them look like the explode out of the hole just sorta slip out.
Old Jul 4, 2008 | 02:05 AM
InSaNeKaMeL's Avatar
InSaNeKaMeL
with mine i was lettin of the clutch around 3500-4000 rpm on 26'' et streets and getting 1.65 60ft's.. i did 5k once and it was still a 1.65
and are u on dr's or slicks? cause if its slicks you need to drop that pressure to at least 12-13
To Launching Tips?
