Fuel Door button dead.....
Jun 30, 2008 | 04:07 PM
From: www.ncminsurance.com Bowling Green KY Home of the Corvette!
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
St. Jude Donor '07-'08
Yes, I am aware I can open it from my trunk....thanks for your help!
The question:
My fuel door switch died and was wondering how hard is it to change?
Thanks!
Adam
Jun 30, 2008 | 04:08 PM
Very easy but you need to pull the console to do it. Check the Vette Essentials websitefor the instructions. If its the actuator thats a tad harder.
Did you check the fuse? Fuse 32 15A.
Any chance you had your dash apart recently and forgot to plug it back in? Good luck.
Jun 30, 2008 | 04:13 PM
Jun 30, 2008 | 04:36 PM
From: HOW FAST WAS I GOING OFFICER? Los Angeles Hating GM Dealership Service Dept.'s Since Sept. 2004
St. Jude Donor '04-'05-'06-'07
Actually the connection is under the arm rest... there's an L shaped connector since it's mounted on a 90º angle...
Jun 30, 2008 | 04:38 PM
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
Jun 30, 2008 | 05:26 PM
CI 3-5-6-7-8 Veteran
The new heap won't pop the fuel door either.
Jun 30, 2008 | 05:29 PM
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13
If you guys are sure its the switch I have a few........I dunno? $8 shipped. PM if you'd like.
Jun 30, 2008 | 05:35 PM
I will pull the center console to see if it is disconnected.....
It may be the switch itself, I will let you know mrm if I need one..
Adam
Jun 30, 2008 | 05:36 PM
real easy
oak
Jun 30, 2008 | 10:26 PM
Quote:
Originally Posted by
DeeGee
Hope it turns out to be something simple.
