CLB question
Old Jul 8, 2008 | 04:40 PM
Crab's Avatar
Crab
Originally Posted by LaMagred02
chill out dwayne....I have read this forum long before I joined.....thus my response
Well then Junior I guess you have'nt read it long enough to know, that if you don't have anything useful to add to help someone.......don't post Otherwise you are just a drive-by azzhat . BTW you really need to fill out your profile.......Junior
Old Jul 8, 2008 | 05:07 PM
LaMagred02's Avatar
LaMagred02
Many have posted "beating a dead horse"......
RIF buddy
this was my first post btw....http://forums.corvetteforum.com/show...&highlight=clb
Old Jul 8, 2008 | 08:30 PM
Jet-Jock's Avatar
Jet-Jock
If you install a bypass module, after ensuring the lock pin has retracted (procedure involved) the power connector to it is removed. The pin and actuator can no longer move because there is no power to the unit.
Answer to the if I install ... will it fix..., most likely yes, read the explanation above.
Old Jul 8, 2008 | 08:47 PM
Slick Rick's Avatar
Slick Rick
Only if you have an aftermarket CLB, COH etc. If you have the gm k-harness the actuator is still in play. That is what he is hearing. And if the steering wheel plate was removed it wont lock when ignition is shut off. For all the information any of you guys need you need to read the sticky...............
Old Jul 9, 2008 | 04:25 AM
HawnHog's Avatar
HawnHog
Originally Posted by av8or
You won't hear the Bzzzzzzt sound of the latch mechanism after CLB install (because the latch is no longer moving).
My local Chevy dealer is still honoring the latest recall. The service manager was surprised when I told him about the reported Feb 28 expiration date...he said that safety recalls can be superceded but don't "expire"
Jack, the "official" letter from GM (dated Feb 2006) states in no uncertain terms that as of Feb. 29, 2008 GM will no longer honor warranty repair/replacement work to the column lock system found on C5's.
If your deraler is willing to fix/replace the column lock system they are to be congradulated. I couldn't find one here in Hawaii that would do a fix after that date. I spoke to the GM division rep here as well as GM's Corp. Customer Service Dept. They swear their "fix" works!!!!! Ha! We know better.
After much go around with the Corp. rep he gave me a refference number and told me IF the system failed to take it back to the dealer that did the original warranty "fix" with the refference number he gave me. That would authorize them to fix/replace it. Here's the problem; the warranty work was done in Texas where the car was originaly sold. The car is now with me here in Hawaii. His comment; Sorry! Can't help you.
To those that don't have a dealer like Jake's who is willing to step up to the plate, get a CLB.
Old Jul 9, 2008 | 08:07 AM
Jet-Jock's Avatar
Jet-Jock
Sorry I should have been more clear, the bypass module as sold by Corvettes of Houston.
