Bent rim... Noooo!
Old Jul 21, 2008 | 02:50 PM
Jedimaster's Avatar
Jedimaster
Default Bent rim... Noooo!
So, I just got my first set of tires for the car... had the shop do a Road Force balance on them but found out that 2 of my rims (one front, one rear... both on the right side) were bent on the inside bead. The front tire would not balance, but the rear would... So, I have the Polished aluminum C5 rims on it and now I need to get replacements. I think I will get a full set of 4 since the ones I have are slightly scratched and I don't want one side looking better than the other. Anyone know of a good place to find these rims? I am also considering getting some aftermarket rims instead of the stock polished aluminum, but I can't afford a whole lot. Opinions... Comments???
Thanks, guys...
Old Jul 21, 2008 | 02:53 PM
jdmvette's Avatar
jdmvette
Night Owl for life
use the force.
Old Jul 21, 2008 | 02:59 PM
Robertelarkin's Avatar
Robertelarkin
Default Wheels
I had a similar thing happen to me...........I searched a lot of places, but I found what I needed, which are the 50th Anniverary wheels, front right and rear right for $185/each at: Detroit wheel & tire. Good Luck
http://www.detroitwheelandtire.com/s...2003&model=776
Old Jul 22, 2008 | 09:55 AM
Jedimaster's Avatar
Jedimaster
No one has any other suggestions as to where to get a replacement set of rims? Hello???
Old Jul 22, 2008 | 09:58 AM
lucky99's Avatar
lucky99
house of wheels you can get 4 speedline for 500.00 they are a vendor on this forum
Old Jul 22, 2008 | 10:23 AM
rws.1's Avatar
rws.1
Strange, I just bought new tires and hadmy polished OEM wheels road force balanced and both right side were also bent.....
Check out the C5 parts for sale section.
Mine were able to be balanced so I wont be competing against you....
Old Jul 22, 2008 | 10:38 AM
Torchblue's Avatar
Torchblue
You might want to try Wheel Collision in Bath, Pa at www.wheelcollision.com
Old Jul 22, 2008 | 11:05 AM
Jedimaster's Avatar
Jedimaster
Thanks guys... can someone give me a good place for new aftermarket wheels? I want to compare the price of replacing with stock versus getting a new set.
Thanks...
Old Jul 22, 2008 | 11:54 AM
Mike McCoy's Avatar
Mike McCoy
If you like what you have now, how about getting them straightened? There are several companies out there that can repair your rims for less than new wheel prices.
Old Jul 22, 2008 | 11:58 AM
lil vette's Avatar
lil vette
If your looking for inexpensive....I know freee
Did you notice a problem before your were told.
Bring by my place, I got a 10 lb sledge or Leave as is.....I seeeeee nothin....
Old Jul 22, 2008 | 12:02 PM
my6thvette's Avatar
my6thvette
There are probably a lot of places that can straighten them for you. I have one here locally that has done several for me for $45 each. You might ask one of your local tire shops if they can recommend one close to you.
Old Jul 22, 2008 | 03:04 PM
Try House of Wheels, TomZWheels, or one of the vendors on the forum that specializes in used parts.
To Bent rim... Noooo!
