Cold Air Intake
Old Jul 22, 2008 | 09:59 AM
GETOPLES's Avatar
GETOPLES
Default Cold Air Intake
I need to decide between SLP Blackwing and Halltech Stinger...anyone have any suggestions on this decision? tx
Old Jul 22, 2008 | 10:01 AM
MagRedConv's Avatar
MagRedConv
Suggest a search on each name; you'll find more opinions/suggestions than you ever thought possible.
Old Jul 22, 2008 | 10:04 AM
GETOPLES's Avatar
GETOPLES
I did that and unfortunetely most responses were not even corvette owners. As a result i thought i could get better feedback from the forum members.
CCA Corvette Parts's Avatar
CCA Corvette Parts
Premium Supporting Vendor
St. Jude Donor '07-'08,-'13-'14, '16-'17
Stinger, it comes with the air bridge...
Peace
Chip
__________________
..................Click for
Old Jul 22, 2008 | 10:08 AM
MagRedConv's Avatar
MagRedConv
Where did you search? Here on the Forum?
Old Jul 22, 2008 | 10:20 AM
rws.1's Avatar
rws.1
Neither...
VaraRam... if you want real performance improvement.
Old Jul 22, 2008 | 10:25 AM
Purdone's Avatar
Purdone
I have a blackwing for sale. $175 shipped.
PM if interested.
Old Jul 22, 2008 | 10:37 AM
chaase's Avatar
chaase
St. Jude Donor '12
I have a Halltech Stinger and its been good to me.
Old Jul 22, 2008 | 11:05 AM
Ol'55's Avatar
Ol'55
From: Southern New Jersey, The wet part at the bottom
St. Jude Donor '08-'09-'10
I like my Callaway Honker, But get comfortable, 'cause you're going to get declarations of many CAIs as the "best" only because most folks will be thinking that their choice is the best available. IE; all the folks that bought a "Sponge Bob" CAI will tell you that it works great, fits like a glove, and dynoed a 25% increase in both HP and MPG.
Bottom line anything that breathes ambient air temps rather than hot engine bay air is an improvement over stock. Continue the search.
Old Jul 22, 2008 | 11:14 AM
BUGZ's Avatar
BUGZ
Same here
Old Jul 22, 2008 | 01:30 PM
GETOPLES's Avatar
GETOPLES
Just looked on the VaraRam website...man that looks impressive!!!
Old Jul 22, 2008 | 01:40 PM
LMH4C5's Avatar
LMH4C5
National Champs Gators 4 St. Jude '09
Originally Posted by rws.1
Neither...
AMEN !
Old Jul 22, 2008 | 01:58 PM
jrose7004's Avatar
jrose7004
Just get a Blackwing and be done with it!
Old Jul 22, 2008 | 02:01 PM
fireman591's Avatar
fireman591
I have the Whitewing and love it!
Old Jul 22, 2008 | 02:20 PM
jpandes's Avatar
jpandes
Originally Posted by LMH4C5
AMEN !
Old Jul 22, 2008 | 02:44 PM
VenomStriker's Avatar
VenomStriker
Callaway Honker
Old Jul 22, 2008 | 02:48 PM
Dave68's Avatar
Dave68
My costs may be a bit off, but most of what is stated here is based upon my experience with aftermarket intake systems for the C5....
If you live in California, think twice about the Vararam, as it can be a royal pain to install/uninstall/reinstall for smog tests. If you live in a state that doesn't have visual inspections, then also take a look at the following (grouped by cold air and non-cold air, but in no particular order) and my comments, if any:
Vararam: Brings cold air in through the fog light panel area to a panel-type filter. Owners have had good luck with system on the dragstrip, but plan on spending hours to install and a bit more to get everything lined up well. Downside: Eliminates engine bay-cooling air that would've come in from the fog light panels (Z06 or coupe/vert with opened-up panels), so the engine bay may end up being toastier, especially if you add headers later. $300-$400 (NOT smog legal in CA)
Vortech Rammer: Brings cold air up from in front of the radiator and into an enclosed box. Its filter is quite a bit smaller than the Halltech Warhead or Blackwing unit. $250 (NOT smog legal in CA)
Callaway Honker intake system: This one relocates the MAF so that it is just in front of the throttlebody. It directs cold air from underneath and costs about $500. I believe this unit is 50 states legal (smogwise) for non=Z06 C5s. Excellent design and quality. If cost is no object, this bad boy should be at the top of your list.
K&N FIPK: This is more of a semi-cold air system, as the cold air intake opening is more of a slit. Its filter endcaps are carbon fiber. However, it is configured similarly to the Halltech Stinger-R and is 50-states legal. $350
Reverse Zip-tie: Allows cold air to be drawn in from underneath, but the bare filter is exposed to potential damage from larger objects. The advantage here is that you may pass smog if the tech doesn't know "which way is up".
Warm air systems: (Easy installation)
Halltech Stinger-R: Not only contains the massive Warhead filter, but also includes a larger-than-stock airbridge and smooth throttlebody coupler. For $350.00 or less, this system represents one of the best bangs for the buck. Fortunately, if you don't like Z06 screens in front of cored-out fog light panels, (for about $40) you can add cold air induction. See my procedure at http://www.conceptualpolymer.com/corvette_c5_corner.htm
This is what I did and a swap to smog-legal status is very easy to do, as I have kept my Z06 intake box.
Halltech Stinger SSM: This intake system features an even larger filter than that of the Stinger-R, TRAP, and Blackwing. < $400
Blackwing: Includes just a large filter, but an excellent one at that. Its cost is close to that of the Stinger. Like the Stinger, it is not smog-legal in CA, but can easily be swapped.
Volant Twin Cone: This system gives you more open filter surface area than any stock box does and is well suited to an engine bay that gets cold air in from the fog light panels, as the filters are more or less in the air flow path. $265
2002+ Z06 airbox cover: A larger opening allows more air to be drawn in through the filter. Expect up to a 5 RWHP gain from this simple swap. $50
Zip-tie: An easy and inexpensive mod (eliminates the OEM box’s upper lid), but its sealing ability is questionable at best.
According to Jim Hall of Halltech, at 95-degrees IAT, the Blackwing (and other non-CAI intakes) will lose 1 degree of timing. At 135-degrees a full 12 degrees is pulled on the LS1 which equals 10 RWHP.
I measured before and after air intake temperature data with a stock Halltech Stinger and then with the same intake but with my CAI mod. The difference was staggering:
After sitting in traffic/slow-moving for 10 minutes or so, my stock Halltech setup was pulling in air that reached 145+ degreesF. Even after driving at highway speeds for 15 minutes, the intake temps never fell below 110F or so.
After installing my CAI mod, sitting in traffic/slow-moving for 10 minutes or more never produced more than 110 degrees F intake temps. After driving on the highway for less than a few minutes, the intake temps went all the way down to ambient temperatures (about 80 degrees F).
As far as horsepower gains, most aftermarket intakes will produce about the same horsepower gains if the intake air is kept relatively cool. During the many dyno runs I have seen, each car had its hood open and a large fan blowing air on the radiator. Vararam-equipped C5s produced the same gains as the Halltech and Blackwing-equipped C5s.
As was mentioned, the gains are only achieved permanently if the intake air is kept below a certain level. If not, much, if not all of your gains will be "dialed back" by the ECU.
To Cold Air Intake
Old Jul 22, 2008 | 03:00 PM
Chemdawg99's Avatar
Chemdawg99
St. Jude Donor '12 thru '21
Dave, I am totally with you on your very detailed and accurate post. Particularly with the part I quoted you on.
IMHO and like you said, for a stock or mostly stock engine there is very little advantage between the aftermarket intakes. Just opening up the air box delivers the same results as most aftermarket intakes that aren't a true CAI. That said, a true CAI opens one up for water ingestions issues (something to think about if you are a DD) Again, nice post
Old Jul 22, 2008 | 03:06 PM
black98c5's Avatar
black98c5
I'm very pleased with the Callaway Honker.
Old Jul 22, 2008 | 03:56 PM
Ol'55's Avatar
Ol'55
Me too. Other than it's function, I like the OEM look of it. If you're looking for "Bling" effect, look elsewhere, But I like the fact that many folks don't notice it at all. (my insurance frowns on performance mods).
