trunk popper
Old Jul 24, 2008 | 10:19 PM
convertible lover's Avatar
convertible lover
Default trunk popper
Can anybody give me info on the company that sells the trunk popper? like the name of the company, name or phone #. Thanks Jack
Old Jul 24, 2008 | 10:26 PM
countylawdog's Avatar
countylawdog
I just bought a GM FOB off Ebay for like $19.00, included programming instructions ......... works great!
Old Jul 24, 2008 | 10:36 PM
dajora03's Avatar
dajora03
St. Jude Donor '07-'08-'09-'10-'11-12-'13-'14-'15-'16-'17
PM me. don't know if it's legal to post info.
Old Jul 24, 2008 | 10:41 PM
convertible lover
Thanks PM sent.
Old Jul 24, 2008 | 11:11 PM
convertible lover
still looking for the phone # anybody have it?
Old Jul 24, 2008 | 11:13 PM
Ronnie55's Avatar
Ronnie55
Works great!
Cheers.
Ronnie
http://www.c5trunkpopper.com/
Old Jul 24, 2008 | 11:14 PM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
Just what is it you are looking for? Key Fob? Pry Bar? You can get them everywhere, GM sells them, The big auction site the list goes on.
Old Jul 24, 2008 | 11:25 PM
convertible lover
the trunk popper is a spring that goes in the trunk on a convertible to open the trunk. without it, it does not open enough to get a hold of. thanks
Old Jul 25, 2008 | 01:13 AM
DeeGee's Avatar
DeeGee
If you can be bothered with the DIY I posted this a while ago:
Trunk Popper for a Vert or Z06
This is an easy mod but for those of you who prefer to buy the ready made item it sells for a very reasonable price of $15.95 from one of the Forum vendors. Unfortunately the vendor doesn’t ship overseas so I needed a DIY version:
If you want to try yourself, pick up a 7/8” compression spring from Home Depot. They retail at $3.98 for a pack of 4 springs, 2 large and 2 small. You’ll also need an end cap of the same diameter. I used a 7/8” rubber stopper ($1.76). The advantage is that it acts as a soft buffer and can be trimmed to fit.
Cut the large spring to a length of 2”. The springs are quite strong so it takes a bit of elbow grease to cut it. Tighten the radius at the cut end of the spring to give a hole to fasten the screw through.
Undo the T30 torx screw on the right hand side of the closure plate. Insert the torx screw down the barrel of the spring and retighten it in place.
Slot the bung in place. You can trim the bung to get whatever fit you prefer. With it as shown it takes a good push to close the trunk. Trimming the bung will make it easier to close..
It took 10 minutes and all the lubrication and fiddling with the lock are a thing of the past.
Old Jul 25, 2008 | 11:34 AM
BuckIVette's Avatar
BuckIVette
Originally Posted by Ronnie55
Works great!
Cheers.
Ronnie
One of the best mods I have done! Without a doubt!
Old Jul 25, 2008 | 11:43 AM
convertible lover
Thanks for the idea DeeGee, I am trying to get the info for a friend. I will foward the idea on to him. Thanks Jack
Old Jul 25, 2008 | 11:45 AM
convertible lover
I agree with that. On a trip this past week I showed mine to a friend and now he wants one.
To trunk popper
