tps
Old Aug 13, 2008 | 05:46 PM
uniqvett's Avatar
uniqvett
Default tps
Rear sensors are leaking around stem any quick fix.
Old Aug 13, 2008 | 05:50 PM
fireman591's Avatar
fireman591
Make sure the nut did not come loose.
Old Aug 13, 2008 | 05:51 PM
10U 99's Avatar
10U 99
St. Jude Donor '08-'09
gently tighten nut 1/4 turn and see if it stops or decreases
Old Aug 13, 2008 | 06:05 PM
fireman591's Avatar
fireman591
Here is a shot from the inside.
If you can't get it to stop leaking you will need to replace the O-ring that goes between the rim and sensor.
They can dry out with age.
Most tire shops should be able to help ya out.
Keep us posted
Old Aug 13, 2008 | 06:16 PM
roscoe118's Avatar
roscoe118
Keep us posted
Wow, how did you get a camera in there??????
Old Aug 13, 2008 | 11:03 PM
I agree that if the nut is not loose, then it is most likely the o-ring gone bad. You can get a new o-ring and have it installed.
Old Aug 14, 2008 | 06:38 PM
uniqvett's Avatar
uniqvett
Thanks everyone who chimed in , replace o-ring and tire is holding.
To tps
