I am going to buy an 04 C5 later this week with 55k miles on it. What will need to be looked at when it hits 60k miles? How much should I expect the check up to cost?
I searched but all of the links I clicked on were from 2005 and didn't work anymore.
I recently got all my belts and belt accessories replaced because they started to squeak around that mileage. I would also look into replacing the plugs and plug wires. If its an auto I would replace the tranny fluid too. That's what I did.
As you can see the maintenance schedule is not too demanding on this car 60k is uneventful.
FWIW my car has 40k miles on it. I changed my air filter at 30k and did the plugs and wires and the accessory belts recently. I'll go for transmission fluids (A4) and coolant at 50k. I trust the DIC on oil life but nowadays it hits the one year point before 0% life.
You can get Gatorback belts at Autozone for about $50 the pair. The OEM belts are way more expensive $100+.
