Jacking Pucks
Old Aug 19, 2008 | 03:20 AM
IDM's Avatar
IDM
Default Jacking Pucks
I'm looking to buy these
Should I get 2, or 4 in case the car is on a lift?
What have you guys found to be the best bang for the buck pucks?
I assume they are all about the same so Im just looking for the best price?
Thanks!
Old Aug 19, 2008 | 04:01 AM
Elite Engineering makes some great aluminum pucks. Or you can go to the BMW dealer and get a set that works well too.
If it were me, I'd get 4 of them - you never know when the car will need to be put on a lift.
Old Aug 19, 2008 | 04:48 AM
ljthe2nd's Avatar
ljthe2nd
I've been using the BMW pucks for 4 years, you just snap them in and they stay in. You don't have to remove them like the aluminum ones because they only stick down about 3/4", and once you snap them in they won't fall out when you drive, as I said mine have been in for 4 years. Plus they're cheaper than the aluminum ones, $28 as opposed to about $50. Here a link to a thread where you can get all the info, go to the second page, it's got the part number and a link to bavarian auto where you can buy them.
http://forums.corvetteforum.com/show...king+pucks+bmw
Old Aug 19, 2008 | 07:39 AM
10U 99's Avatar
10U 99
St. Jude Donor '08-'09
if you're going to be continually using the pucks then go with the high dollar units, they might hold up better. but for occassional use the inexpensive hockey pucks will last you a life time. in the last year I've used my "cheapies" maybe ten times and they show no wear. put the difference in price in some other mod.
Old Aug 19, 2008 | 07:44 AM
jrose7004's Avatar
jrose7004
I got 4. I got them worth the money on E-Bay!
Old Aug 19, 2008 | 08:24 AM
gray-c5's Avatar
gray-c5
St. Jude Donor '08
I bought pucks because of the comments here at the forum. However, when I went to get a tire fixed at Discount tire, they laughed. They never use them. I offered to get them out so that they could jack up the car and they insisted on not using them. At any rate, they jacked the car up, and fixed the tire for free. No problem, no damage. So it seems that the jack pucks are yet another corvette dump @ss cost. A lot of hype to sell yet another useless item. I'm sure that they are nice to use, but not a necessity.
Old Aug 19, 2008 | 08:29 AM
DropTheTop's Avatar
DropTheTop
You forgot the link!
http://forums.corvetteforum.com/show...ight=bmw+pucks
Old Aug 19, 2008 | 08:31 AM
Jet-Jock's Avatar
Jet-Jock
Discount tire did mine that way too, however that was before I had bought a set of the EE aluminum ones. They didn't do any damage, but I'm curious that they preferred you didn't use them. So what happens when they cause damage, yeah they are out a few bucks but your car has been damaged and then repaired. So I wonder then is their lift different, or their method... I wonder what it is that they don't want to use them. What would have happened if you stuck them in while in the parking spot before pulling it in to the bay?
Old Aug 19, 2008 | 08:35 AM
Gray Weasel's Avatar
Gray Weasel
Default jacking pucks
Had mine since 03 no problems
Part # for Round ones 51 7119 60 752 For SQ ones 51 7182 68 885:
Old Aug 19, 2008 | 08:42 AM
k0ts's Avatar
k0ts
You can make them for from $5-10...
Old Aug 19, 2008 | 09:10 AM
gray-c5's Avatar
gray-c5
St. Jude Donor '08
I guess if they break your car, they are responible. It's seems that they really are responible if you point out the potential problem. I don't know why they did not want to use them. They said they lift vettes all of the time and I guess they don't want to confuss the guys with different methods of lifting. I have to give Discount tire credit. I have used them for years. They fix flats for free, even if you did not buy the tires from them. They do good work and I've never had a problem with them. Truely a good company to do business with. I guess you could find someone a little cheaper, but why? When I need to replace my tires, they will get my business. I only have to figure out which tires I want. And that is a hard thing to do with all of the hype about this tire and that. I think I'm down to either the original tires again, or Michelins A/S run flats for the noise and mileage. The GYs do work great, and when I got two nails in one and went all the way to zero psi, I was still able to drive to Discount tire to get it repaired. I got there just before closing on a friday evening! They fixed it with no pucks and no charge.
Old Aug 19, 2008 | 09:19 AM
ljthe2nd's Avatar
ljthe2nd
Originally Posted by DropTheTop
Thanks, fixed it, but this is the link I meant to post.
Old Aug 19, 2008 | 09:55 AM
egypt123's Avatar
egypt123
Apparently the BMW dealer got word of the Corvette tax. They're $14.95 now as opposed to $6.95.
Old Aug 19, 2008 | 10:04 AM
BUGZ's Avatar
BUGZ
I second that. had mine for less than a year. They work great. Used them over the weekend changing oil. Put them in and forget about em.
Old Aug 19, 2008 | 10:05 AM
SJSZ06's Avatar
SJSZ06
I put a set of rocker savers with built-in jacking pads on my '02 Z06 - never need pucks again. Plus they already saved my rocker panels once!
Old Aug 19, 2008 | 10:30 AM
10U 99's Avatar
10U 99
Originally Posted by gray-c5
........... when I went to get a tire fixed at Discount tire, they laughed. They never use them. I offered to get them out so that they could jack up the car and they insisted on not using them.
I'm afraid had I requested they use the pucks and they laughed and refused I would take my business elsewhere.
cracked rockers don't heal by themselves.
Old Aug 19, 2008 | 10:43 AM
tracks03's Avatar
tracks03
I bought the EE's as well. When I needed the tires replaced on my '03, I raised the car up on jack stands and took the wheels to the tire dealers. The trick was the jack I was using wasn't quite low enough, so I had to drive one wheel up on a 2x6 board!
When I took my '03 to the dealership to have the rear end leak checked, I showed the mechanic mine to use, but he said he had a set he usually used. See? Sometimes even the dealership mechanics care about the Corvettes as much as we do!
To Jacking Pucks
Old Aug 19, 2008 | 02:03 PM
4440stevesvette's Avatar
4440stevesvette
i BOUGHT MINE SOMEWHERE ON EBAY. BLACK HI-TECK PLASTIC ONES THAT YOU JUST SNAP IN AND LEAVE THEM IN PLACE. THEY WORK GREAT. PRICE WAS ABOUT $28.00 PLUS SHIPPING.
Old Aug 19, 2008 | 03:55 PM
04 commemorative's Avatar
04 commemorative
St. Jude Donor '17
I also bought the BMW snap ins and they never come out.
Old Aug 19, 2008 | 04:07 PM
The Last Captain's Avatar
The Last Captain
This is what happens when you do not use the pucks.
http://forums.corvetteforum.com/show....php?t=2110025
