Ever use ramps?
Old Aug 20, 2008 | 12:03 AM
mbroadway's Avatar
mbroadway
Default Ever use ramps?
Just wondering how many of you have used ramps in your garage to get under your car. Are they safe? How hard is it to drive up on them without overshooting, and what's the secret for doing it right?
Where did you get yours and how expensive are they?
Thanks for all replies.
Michael
Old Aug 20, 2008 | 12:32 AM
CaliforniaJack's Avatar
CaliforniaJack
Default Ramps
I use two 2"x12" boards 8ft. long with one end on cinder blocks. Most commercial ramps are too narrow or steep for a C5.
Old Aug 20, 2008 | 12:34 AM
2000lambovette's Avatar
2000lambovette
I use race ramp, best investment ive made. Great for detailing under car, oil changes etc. Very strong and wide enough even for my 18x12 rears.
Old Aug 20, 2008 | 12:37 AM
jornahow's Avatar
jornahow
I got some ramps on sale for $24 at Schucks. Just used them to fix my clunking stabilizer bar. They're light, easy to use - best $24 bucks I've spent on the Vette.
Old Aug 20, 2008 | 12:59 AM
mbroadway's Avatar
mbroadway
Thanks for the replies, guys. Does it make you nervous when you drive up on them, thinking you might overshoot? And how do you prevent that? I think that would be a disaster.
Michael
Old Aug 20, 2008 | 01:01 AM
Z06ster's Avatar
Z06ster
Tried race ramps but didn't like them. I had the $200 dollar set and they didn't bring me up high enough... granted I am lowered on stock bolts. I had a tough time doing an oil change... reaching back for the oil filter was a major pain. For another $100, there was another set that would have brought me higher and probably would have been better, but at $300 I thought that price is outrageous... At that point, I will just save up for a kwiklift.
Old Aug 20, 2008 | 01:35 AM
DeeGee's Avatar
DeeGee
I have a set of the gray Rhino Ramps from Walmart and they work just fine. Thres a little slip trying to get on initially but a small piece of wood to get over the lip cures that. Providing you take it slowly there should be no risk of overshoot.
Once the cars up its rock solid.
They cost a massive $35
Old Aug 20, 2008 | 01:48 AM
Riley P's Avatar
Riley P
I've used the Rhino ramps 12000. Not really high enough, but good enough for width. I use 12x2's to increase the height of the ramp, with a 2x2 screwed in the end to help keep the ramp from slipping out. This works alright. You can tell when the car is far enough because it doesn't want to roll back, just take it slow, you don't need to hit the stops. But, in the end I would rather have a lift.
Old Aug 20, 2008 | 01:57 AM
Joe0121's Avatar
Joe0121
St. Jude Donor '06
My car is lowered, so on level ground no way, going down hill on a drive way it worked but is un-nerving while under the car. They are however wide enough and with a spotter no risk of over shoot. I think a piece of wood would help matter greatly, ill have to try it as well as some chocks for the back wheel with the e-brake om and you should be in the money.
Old Aug 20, 2008 | 06:01 AM
rws.1's Avatar
rws.1
I use Rhino Ramps. The ar emore tha strong enough for the Vette. I have driven my Silverado on them....
The issue for me is the height... borderline for most things at best.
Old Aug 20, 2008 | 07:01 AM
damilleniumboy's Avatar
damilleniumboy
I use them to do oil changes all the time. I do drive up a couple of 2x4's just to get that inital lift because the car is so low, but it's no biggie once it gets on the ramp.
Old Aug 20, 2008 | 07:09 AM
warren s's Avatar
warren s
Rhino ramps work great, and they have a "stop" at the end of the ramp to prevent driving off the end.
Old Aug 20, 2008 | 07:13 AM
ljthe2nd's Avatar
ljthe2nd
I've been using a set of these for 4 years now http://www.discountramps.com/sports_car_ramps.htm they work great. I'm a pretty big guy (girth wise ) and these get the car up high enough to where I have no problems changing oil. They are very sturdy, and easy to drive up on. They have the stop as part of the ramp so there's no danger of accidentally driving off the end. You can really feel the stop, you would have to really give it extra gas to go up and over the stop. I'll probably be selling these locally since I have a sissors lift scheduled to be delivered today.
Old Aug 20, 2008 | 08:10 AM
Patches's Avatar
Patches
Been known to use them . . .
Old Aug 20, 2008 | 08:43 AM
bumble-z's Avatar
bumble-z
Made up my own set.
Old Aug 20, 2008 | 09:29 AM
Mike Mercury's Avatar
Mike Mercury
for the DIY'er:
http://mikemercury.home.att.net/ramp.htm
Old Aug 20, 2008 | 10:24 AM
bucwheat's Avatar
bucwheat
I use a 2x10 in front of the ramp,works well.
To Ever use ramps?
Old Aug 20, 2008 | 10:32 AM
mschamberger's Avatar
mschamberger
Originally Posted by bumble-z
Made up my own set.
That's a great looking setup.
Old Aug 20, 2008 | 04:07 PM
borkg2006's Avatar
borkg2006
Do a search using Murphy ramps and you'll find a set of plans for a pretty good set. I made my own but not like these and used them to install my VaraRam and my cat-back. Very safe and sturdy.
Old Aug 20, 2008 | 04:17 PM
3rdvette@60's Avatar
3rdvette@60
