Remove door panel to replace door sub?
Old Aug 26, 2008 | 12:04 PM
1sickz51vette's Avatar
1sickz51vette
Default Remove door panel to replace door sub?
Does the door panel have to be removed to replace the drivers door sub? I am hoping that I can just remove the grill itself, and save myself some time. If not how hard it is to remove the panel without messing it up? Thanks guys!
Old Aug 26, 2008 | 12:53 PM
clayton1's Avatar
clayton1
Banned Scam/Spammer
Gotta remove door panel. Not hard, do a search and you`ll find instructions.(I don have time to explain right now)
Good Luck
Old Aug 26, 2008 | 12:55 PM
Doug@MorosoPerformance's Avatar
0Doug@MorosoPerformance
Former Vendor
You will have to remove the door panel, but it is easy. Click on the Vette Essentials link below for instructions.
http://www.vetteessentials.com/instr...or_handle.html
www.moroso.com
Old Aug 26, 2008 | 12:57 PM
J S Machine's Avatar
J S Machine
St. Jude Donor '10-'11-'12-'13-'14-'15-'16-'17
St. Jude Knife Maker
That speaker is like a whole unit if I remember correctly. You will have to use an adapter plate to put aftermarket mids or the like back in there. Check over in the audio / electronics board. those folks will know
Old Aug 26, 2008 | 02:08 PM
MagRedConv's Avatar
MagRedConv
Check out the Audio section; there's a step by step for the removal.
Old Aug 26, 2008 | 05:36 PM
1sickz51vette
I know i was able to disconnect the small sub with just removing the grill, I thought i remember it looking like I could just unscrew the 8" sub and pull it through the grill.
Don't quote me on that though, just seeing if anyone else did it!
Old Aug 26, 2008 | 05:44 PM
ljthe2nd's Avatar
ljthe2nd
You have to remove the door panel to remove the grill.
Old Aug 26, 2008 | 08:43 PM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
correct door panel has to come off to remove sub or u will break the grill
Old Aug 27, 2008 | 12:15 AM
1sickz51vette
Hmm weird, I got the grill off and on just fine! Maybe I got lucky lol...
Old Aug 27, 2008 | 12:34 AM
ljthe2nd's Avatar
ljthe2nd
You might have got it off ok, but the tabs on the grill that hold it on, have to be pushed through the door panel and bent over from the back side, I don't know how you can do this with the door panel in place. If you just pushed them through the slots in the door panel and didn't bend them over from the back side, they won't be tight and will rattle.
To Remove door panel to replace door sub?
