Battery change
Old Aug 29, 2008 | 08:34 AM
dennyb7's Avatar
dennyb7
Default Battery change
Wanted to know, when you change the battery, if you loose any stored imfo and also,this should be good,what battery brand to use.Thanks guys,Denny
Old Aug 29, 2008 | 08:41 AM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Denny there are so many choices to go with!
You will only loose the radio information (Clock etc)
Look for a battery within your budget, I have a Costco battery in mine and it has lasted for a few years so far - an no problems!
Thanks,Matt
Old Aug 29, 2008 | 10:31 PM
bobby777's Avatar
bobby777
Battery=who knows--got mine at auto zone- have a 1980 vette--lasted for 28 years ya think its good one
Old Aug 30, 2008 | 07:14 AM
Wheelboyo's Avatar
Wheelboyo
Just lost the clock setting on my car. The radio pre-sets were ok.
Old Aug 30, 2008 | 07:20 AM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
Good old Delco battery, The Optimas are over priced.
Make sure your radio isn't in AntiTheft mode on, If it is you will need the code if lost power for too long. Everything else is easy to correct.
Old Aug 30, 2008 | 11:42 AM
dennyb7's Avatar
dennyb7
Hey Bill,how do I know if anti theft is on. thanks
Old Aug 30, 2008 | 11:56 AM
fixvet's Avatar
fixvet
Old Aug 30, 2008 | 11:59 AM
Mr.Bill's Avatar
Mr.Bill
The red light on the radio will flash when the key is out.
Here is a link on how to turn the antitheft on and off.
Bill K
http://forums.corvetteforum.com/show...70&postcount=9
Old Aug 30, 2008 | 01:52 PM
dennyb7's Avatar
dennyb7
Bill K
Bill, thanks for the imfo.Question, the lite, I'm assuming, is by the volume control? Well if thats it,my lite is not on.
Old Aug 30, 2008 | 02:36 PM
Mr.Bill's Avatar
Mr.Bill
If your lite by the vol isn't flashing when the key is out of the ign your anti-theft is off.
Old Aug 30, 2008 | 02:49 PM
dennyb7's Avatar
dennyb7
Excellent......thanks for your help.Just wondering...could you keep a trickle charger on cables to keep from loosing code if you had to?
Old Aug 30, 2008 | 07:16 PM
Sabre34's Avatar
Sabre34
Moderator
St. Jude Donor '06 thru '26
Old Aug 30, 2008 | 09:50 PM
Could lose clock setting and radio could get locked if theftlock is set. I had an Optima Red Top in mine for over 6 years - always served me well.
Old Aug 31, 2008 | 03:58 AM
DeeGee's Avatar
DeeGee
Its worth knowing your code in an case
Heres an easy way to find out the code:
https://www.corvetteforum.com/techti...=164&TopicID=1
Old Aug 31, 2008 | 12:16 PM
fireman591's Avatar
fireman591
My battery conditioner has a option to plug it into the cigarette lighter to charge the battery.
You can plug it in and remove the battery and not loose any memory.
Just be careful with the positive cable when changing the battery.
It will be charged from the battery conditioner being plugged into a cig lighter .
Have a good one
Fireman591
Old Aug 31, 2008 | 12:56 PM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
St. Jude Donor '08-'09
sears die hard gold series. they dont leak at the posts like AC delco batteries do.
Old Aug 31, 2008 | 01:00 PM
Mr.Bill's Avatar
Mr.Bill
LOL, AC DELCO fixed that trouble years ago.
Old Aug 31, 2008 | 01:20 PM
DeeGee's Avatar
DeeGee
The trouble is Bill, quite a few of our fellow members are sitting on the old AC Delco batteries that may leak
Hopefully, there are enough posts about the dangers of the old batteries to make people change them before they leak on the BCM.
Old Aug 31, 2008 | 01:24 PM
Mr.Bill's Avatar
Mr.Bill
Agreed, But the OP was asking what to buy and the other guy that posted and said the Delcos leak and that is not true if the OP wants a new battery. I don't think the OP is going to buy an old battery.
To Battery change
