no internal temperature sensor?
Old Aug 29, 2008 | 04:22 PM
Svelte_C5's Avatar
Svelte_C5
St. Jude Donor '09
Default no internal temperature sensor?
I just took my dash out to install an ipod cable and a turn signal, and in the process I never noticed an internal temperature sensor! I know it's supposed to be here behind the little slotted pop-off cover:
But when i popped off that cover there was no sensor there, and i couldn't see one anywhere else under the dash where it might have come loose and been laying somewhere.
What should I do now? My AC works well on long trips, but on short trips is not really that great, I usually just roll the windows down. Could this be why? it's a '99 fwiw...
Old Aug 29, 2008 | 04:29 PM
DeeGee's Avatar
DeeGee
Thats the inside air temperature sensor
Without that the HVAc has no reference for setting the temperature
Easy to replace
Old Aug 29, 2008 | 04:35 PM
10U 99's Avatar
10U 99
St. Jude Donor '08-'09
I can see part of it in that pic...... kind of looks like a small capacitor. should be a small two wire mini plug in the back. you'll have to removed the panel under the column to replace it. not a big deal
Old Aug 29, 2008 | 05:00 PM
euro@EFIAlchemy.com's Avatar
0euro@EFIAlchemy.com
Former Vendor
Off the top of my head, i believe if you have the manual controls (2 ***** instead of the digital climate control) then the car wont have a inside air temp sensor?
Old Aug 29, 2008 | 06:36 PM
Last C5's Avatar
Last C5
I know the 99 FRC doesn't have an inside sensor. What model are you running?
Old Aug 29, 2008 | 06:42 PM
DefenderC5's Avatar
DefenderC5
I believe you are right. My manual single zone HVAC (3 *****) doesn't have an inside air temp sensor... didn't see it when I had my dash apart. It was my understanding that only dual zone climate controls (digital temp screen) needed the sensor too.
Old Sep 2, 2008 | 10:27 AM
Svelte_C5's Avatar
Svelte_C5
St. Jude Donor '09
Yeah I have a 99 with the manual controlls with the three *****. Guess there's no need to worry then. Thanks.
To no internal temperature sensor?
