Odd tire wear pattern?
Old Sep 2, 2008 | 09:28 AM
MisterC's Avatar
MisterC
Default Odd tire wear pattern?
I noticed my daughter's coupe (formerly mine) is showing tread wear in the middle on the rear tires. I did, and my s.i.l. does, pay close attention to tire pressure so I was wondering if anyone else saw more wear in the center than on the outer edges of their rear tires??
Old Sep 2, 2008 | 09:30 AM
Bugaboo's Avatar
Bugaboo
what brand? center wear pretty much indicates overinflation.
Old Sep 2, 2008 | 09:35 AM
c5streak's Avatar
c5streak
Overinflation is a good guess, but I got the same center wear on my Kumho's, which are nearing slick in the center after 21k miles. They have been at 30psi since new, and I do check and adj them often. No, they don't get driven aggressively.
Old Sep 2, 2008 | 11:34 AM
Mike McCoy's Avatar
Mike McCoy
You indicated you keep track of tire pressures. What were/are you running on that car?
Old Sep 2, 2008 | 02:13 PM
jrose7004's Avatar
jrose7004
Mine always wear great on the rear, I have trouble with the inside of the fronts.
Old Sep 2, 2008 | 02:53 PM
Dave68's Avatar
Dave68
Default many variables
The overall weight of the car with driver and gas can make a difference. Let's say you weigh 250 lbs and always keep the tank full. That about 400 lbs added to the car's weight. Now let's say your daughter weighs 100 lbs and averages just a half-tank - that's only about 180 lbs added to the car's weight. Now throw in different tires and ambient temperature and it's almost guaranteed that the tire wear will change.
When I had runflats, I used to keep the pressure set to 30 psi at 70F. The rears always wore in the center, yet other C5 owners obtained good wear results at the same pressure. However Evil Twin commented that he got the best wear when his tire pressures NEVER exceeded 30 psi, even on a 90 degree day at highway speeds.
My advice? Try 27-28 psi.
Old Sep 2, 2008 | 03:08 PM
Corvette00Car's Avatar
Corvette00Car
This is going to sound odd but I recall reading a Michilen posting that if the tire was slighly under pressure the center track would squirm causing excessive wear in the middle. This was stated as especially true in the really wide tires compared to normal america. I also read that Michilen changed their design slightly to accodate this. I too keep accurate attention to tire pressure and even keep records of actual tire ware adjusting pressure accordingly and it wasn't until the latest replacements did I reverse my actions. Well we'll see. But I do get great wear on the daily driver.
Old Sep 2, 2008 | 03:38 PM
JimZRyd's Avatar
JimZRyd
St. Jude Donor '12
I'd say overinflation or even the tires getting too hot which will cause tire pressures to go up. Might even want to consider if someone has been lighting those rears up. The centrifugal force will make the centers push outwards and then they will show more wear on the centers. This is just my initial thoughts.
Old Sep 2, 2008 | 05:47 PM
1970-Bronze's Avatar
1970-Bronze
s.i.l - reporting in
Tire pressure is 27-28 range depending on temperature.
Funny thing - the passenger tire is worse than the drivers.....
Over inflation was my first thought but I have never seen the tire indicater read over 29 which made me wonder how accurate they were........
Old Sep 2, 2008 | 08:17 PM
C5Pat's Avatar
C5Pat
I had a set of Faulkens that done the same thing,They were half wore out when I got the car so I don't know what the previous owner run them at. Instead of 30psi cold, I run my new tires at 27-28 cold depending on the weather temp outside, I think it's very important to keep a close eye on tire press. Rule of thumb, 1Deg. increase for every 10Deg temp change. Just my 2cents
Old Sep 2, 2008 | 08:32 PM
Got uid0's Avatar
Got uid0
St. Jude Donor '17
are you speaking of all four or only the front?
Old Sep 2, 2008 | 10:15 PM
kettemr's Avatar
kettemr
I think the driver's manual says 30 PSI cold. I'm at about 29 cold and 32 hot on all four and wear is even.
Old Sep 3, 2008 | 02:03 PM
1970-Bronze
Just the rears.
Old Sep 3, 2008 | 03:33 PM
travelingypsye's Avatar
travelingypsye
The only other thing I can think of is too big tire on a too narrow rim. Weight, temp ect are all factors too.
Old Sep 3, 2008 | 03:47 PM
JCamaro's Avatar
JCamaro
Depending on exactly how much they're worn in the middle.....a little bit of extra wear in the center of wide rear tires, on rear drive cars.....is pretty normal. It has to do with both the width of the tire and the contact patch while driving.
3-5 psi will not cause overinflation wear.....10-20 psi most certainly could.
I've switched to running 28PSI cold all the way around...because the car handles better, and it reduces the front tires tendency to wear on the inside shoulder and scallop the tires producing vibrations.
I just checked my rears.....and they are worn a little more in the center than in the shoulder area.
Looks normal to me.
Oh I'm running 245/45R17 Bridgestone Potenza RE 050 RFT's on the front
and 275/40R18 Bridgestone Potenza RE 050A RFT's on the back.
JC
Old Sep 3, 2008 | 06:02 PM
Oldvetter's Avatar
Oldvetter
I use 28 psi cold on rears, even wear.
Old Sep 3, 2008 | 06:18 PM
Jet-Jock's Avatar
Jet-Jock
It seems to be normal from my experience and what I have learned by asking around and especially on Michelin PS A/S ZPs. I have two rears that are nearly bald center rib outward, and they go fast once it starts (20K on the tires). Fronts are still in good shape. I'm waiting on the next generation Michelin PS A/S Plus (ZPs) which are supposed to be re-engineered to significantly improve wear. If they hadn't I'd be looking at other types of tires. The new one's should be in Friday. Michelin was for a while suggesting increasing the air pressure but apparently knew about this and was already working on a next gen tire.
To Odd tire wear pattern?
