c5 automatic-specific mpg question
Old Sep 6, 2008 | 04:24 AM
lightnin's Avatar
lightnin
St. Jude Donor '11
04 with 342s. I get about 26 on the highway at about 75.
Old Sep 6, 2008 | 05:42 PM
mschamberger's Avatar
mschamberger
My '04 w/ the 273 "standard" rear can get me 30mpg at 80mph on a wide open road. Speed up/slow down traffic can drop me to 26/27mpg.
Old Sep 6, 2008 | 05:52 PM
TheRadioFlyer97's Avatar
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
Aerodynamically speaking the Targa coupes will get the best milage, followed by the FRCs and finally verts (top down) A top-up vert would have roughly the same aerodynamic properties as the FRC.
My 97 has been slightly modified including larger 32lb lucas injectors but I still manage to get around 27 mpg at highway speeds.
If you have reasonable outdoor temperatures, turning the A/C off and setting the HVAC to vent will save you nearly 2-4 MPG and give you noticably more power.
Old Sep 6, 2008 | 06:09 PM
2K14C7's Avatar
2K14C7
C7 of Year Finalist (stock) 2019
2018 C7 of Year Finalist
Originally Posted by c5streak
Same here.
About what I get with an A4 and 3.15 gears also.
Old Sep 6, 2008 | 06:13 PM
2K14C7's Avatar
2K14C7
For what its worth, when you go to WOT the A/C compressor disengages so the power is the same on or off.
Old Sep 6, 2008 | 06:26 PM
jrprich's Avatar
jrprich
99 A4 3.15 rear
Recent 1400 mile trip in 100+ weather.
28.6 Average with the AC on all the time
Old Sep 6, 2008 | 08:47 PM
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
I did not know that. Good news.
Old Sep 6, 2008 | 10:31 PM
magredoak's Avatar
magredoak
1st Gear
Default C5 Automatic - mpg
I have the 3.15 axle, and get close to 20 in town, and close to 30 on the highway. Your mileage will be reduced if the fuel contains ethanol, since it has fewer btu's than 100% gasoline.
Old Sep 6, 2008 | 10:32 PM
OhioDave's Avatar
OhioDave
St. Jude 15 Year Donor
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16'17-'18-'19-'20-21
'02
Old Sep 7, 2008 | 10:49 AM
gtzy's Avatar
gtzy
1999 A4 w/2.73
34 mpg @55-60 mph
31 mpg @65-75 mph
Old Sep 7, 2008 | 10:57 AM
BOTYNV1's Avatar
BOTYNV1
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19
Highway 750 miles = 31.1, next trip 1500 top down 1/2 time= 29.9, around town avg=23.5 2004 A4 w/3.15.
Old Sep 12, 2008 | 03:16 AM
ferrari red vette's Avatar
ferrari red vette
1998 automatic ... how can i find out which type of gears i have?
what is the difference between the 2, in terms of a) performance, b) mpg ? thanks
Old Sep 12, 2008 | 05:53 AM
  #33
damilleniumboy's Avatar
damilleniumboy
In your diferential there is a plaque, or by looking at the codes in your glove box, it will give you a 2.73 or a 3.15 differential that came from the factory with you A4. The 2.73 will get you up and going slower than the 3.15 will because of the reduced ratio. In MPG, I would say that you will get better MPG in town with the 3.15 because it's easier to get the car moving from a stop that a 2.73 will or might. On the highway, the 3.15 might get you less MPG than the 2.73 will. Now, if you cruise at WOT 24/7, you will get about 5MPG.
I have a 1999 coupe with the 3.15
City driving 19-22
Highway driving 28-32
Old Sep 12, 2008 | 09:35 AM
  #34
bucwheat's Avatar
bucwheat
I get 30-31 mpg on the interstate on cruise doing 65MPH
Old Sep 12, 2008 | 10:14 AM
  #35
EBvette02's Avatar
EBvette02
I average 24.5 in town, 27-28 on road trips.
Old Sep 12, 2008 | 11:28 AM
  #36
mnfmkf's Avatar
mnfmkf
2000 a4
Portland to LA = 32.4 mpg
In town 20.0
Mike
Portland or
Old Sep 12, 2008 | 12:08 PM
  #37
iced98lx's Avatar
iced98lx
1998 A4 w/2.73
32 mpg @56ish mph
31 mpg @72ish mph
30 mpg @ 83ish mph
those are assuming SD traffic (none) and eastern sd hills (practically none)
It's not an exciting drive, but i get good mpg.. lol
To c5 automatic-specific mpg question
Old Sep 12, 2008 | 12:14 PM
  #38
bassman12350's Avatar
bassman12350
Originally Posted by iced98lx
1998 A4 w/2.73
32 mpg @56ish mph
31 mpg @72ish mph
30 mpg @ 83ish mph
Do you have any aftermarket mods? Mine is bone stock w/ 2.73s and I'm at about 26 max at 85 on level pavement. I do have the Michelin "run flats" tho - - hear those can cut into your economy a bit.
Old Sep 12, 2008 | 12:18 PM
  #39
TheLegacy81's Avatar
TheLegacy81
City: 17-20ish
Highway: 24-27(with mild traffic)
Highway with traffic: 19-21
Old Sep 12, 2008 | 12:38 PM
  #40
34RedRage's Avatar
34RedRage
i have a 98 a4 with 3:15 gears... at 70 mph i get 31 mpg
