[Z06] Headlight Motor Problems
Old Sep 12, 2008 | 08:32 PM
66CorvetteCoupe's Avatar
66CorvetteCoupe
Default Headlight Motor Problems
Two weekends ago I replaced the plastic gear on the passenger side headlight motor. Tonight I turned the lights on and the same thing again the right side did not come up. Opened the hood rotated the manual operator a 1/4 turn and light came up same as before I changed the gear. Another thing when you turn the lights off the headlights go down and motor on the passenger side continues to run for approximately 10 secs with a loud grind. It did that a couple of times prior to changing the gear. Is it time to replace that complete motor assembly or is there something I may be over looking? After I replaced the gear all worked as it should I am wondering if there is some wear inside the gear box that may be causing this. Thanks for your thoughts.
Gerry
