Hood Liners
Old Sep 23, 2008 | 03:07 PM
t-boy58's Avatar
t-boy58
Default Hood Liners
Does any Forum Vendor sell hoodliners with the simple corvette emblem design and logo? I don't want anything speciality custom- just tired of the stock one!
Old Sep 23, 2008 | 03:12 PM
DeeGee's Avatar
DeeGee
Its easy to reurbish the stock liner. The decal is just a few $$ from RPI Designs or you can use testors paints.
Refurbishing a Corvette C5 Hood Liner
The liner is made of a very delicate material so be careful in how you handle it once it’s removed. The surface is a fabric type finish and hard brushing will cause it to become rough and fibrous. It will also crack easily if you let it flex so if you take it outside beware of strong wind.
As you take the final fasteners out, support the liner so you don’t crack the liner around the eyelets.
The actual work takes only minutes. The drying time is the only slow process.
As you can see, the liner will have attracted quite a bit of dirt and grime.
OK here we go.
Lift the hood.
Remove the fasteners gently, top, then bottom and middle ones last. This will support the liner better as you take them out. Us a tool with a forked end. I’ve heard of a barbeque fork being used. I used a nail puller work in behind the fastener.
Take the liner outside and brush the surface gently with a soft brush to remove any dirt. Take care not to damage the surface of the liner.
Spray the liner with black paint. The difference between the old and the new surface is immediately apparent.
Use as many coats as you see fit. The liner is porous so it will take at least 3 coats to get good coverage. Leave it for 30 mins between coats to allow the paint to dry.
If you plan to paint the Corvette emblem, you may wish to apply extra paint around the embossed area on the liner. This will stop the liner absorbing the coloured paint.
Once the paint is dry (and you may wish to leave it overnight), you can either paint the emblem or apply a decal. I chose the decal. Alternatively if you prefer, you can refit the liner and apply the decal when it’s back in place.
Refit the liner in the hood fitting the middle fasteners first to hold it in place, then refit the remaining fasteners. A gentle push fit is all it takes to reinsert the fastener.
The finished Hood Liner
Old Sep 23, 2008 | 04:39 PM
poolboy's Avatar
poolboy
because of its size it is expensive to ship them around ($70+). Carmotorsports offers a kit which covers the existing liner - other than that as Deegee suggests, refurbing your own is the cheapest option.
Old Sep 23, 2008 | 04:45 PM
flcpl4fn's Avatar
flcpl4fn
here is a link to Carmotorsports http://carmotorsports.com/UHI_Corvette_C5.htm
Old Sep 23, 2008 | 05:35 PM
jrose7004's Avatar
jrose7004
hoodliners by Paula does them.
Old Sep 23, 2008 | 05:43 PM
with all the above. PaulaH does excellent custom work and the one by CarMotorSports is embroidered. Or you can just do it yourself.
Old Sep 23, 2008 | 06:55 PM
Bills03Coupe's Avatar
Bills03Coupe
Default Hood pad decal
I have the hood pad decal from Cyberdine Graphics, and it looks great! Just follow the instructions when applying the decal, and you'll be fine.
Go to www.cyberdinegraphics.com
Old Sep 23, 2008 | 11:24 PM
PaulaH's Avatar
0PaulaH
Former Vendor
I'd be happy to paint you a new hoodliner!
Old Sep 24, 2008 | 08:49 AM
BIGG DOGG's Avatar
BIGG DOGG
CAA offers an embroidered kit for $150. Any colors you need. Lifetime Warranty to boot.
1-877-712-4222
Old Sep 24, 2008 | 09:54 AM
Remo's Avatar
Remo
Default The Liner Looks Fantastic
t-Boy58 - what paint do you recommend for the overall hood liner?
Remo
Old Sep 24, 2008 | 10:18 AM
t-boy58's Avatar
t-boy58
PM'd you!
Old Sep 24, 2008 | 10:35 AM
Birdman's Avatar
Birdman
Why I DO believe that we have talked before Paula! We emailed back and forth about designs and stuff. (I was using AKO (army))
Can't wait to budget out enough to get one done!
Old Sep 24, 2008 | 12:23 PM
fireman591's Avatar
fireman591
Do it yourself!
$10.00 worth of paint and a $25.00 decal
Piece of cake
Old Sep 24, 2008 | 12:28 PM
GETOPLES's Avatar
GETOPLES
Cool Post. Thanks guys
Old Sep 28, 2008 | 12:59 AM
grotla's Avatar
grotla
Old Sep 28, 2008 | 10:09 AM
97c5vette's Avatar
97c5vette
[QUOTE=fireman591;1567225398]Do it yourself!
Piece of cake
Where did you order the decal for $25
Old Jun 12, 2014 | 11:04 PM
Adrenalin521's Avatar
Adrenalin521
Deserves a bump! ; )
To Hood Liners
Old Jun 13, 2014 | 12:25 AM
o2bnkc's Avatar
o2bnkc
A 6 year old post?
Old Jun 13, 2014 | 01:01 AM
jdvann's Avatar
jdvann
There are several that cover this same subject , some of the newer threads link to the older ones. It is a great subject to share with newer owners.
Old Jun 13, 2014 | 09:13 AM
4XLR8N's Avatar
4XLR8N
Pro Mechanic
Basically the same process as DeeGee, but I used paint instead of a decal...not hard to do at all, just takes a little time and patience...
