I have had my Window Valet now for several years.
The automatic door unlock has ceased to work when hand brake is set.
Any ideas on the fix would be appreciated.
Thanks,Tom.
Did you try removing the valet from the module and re-inserting it? It may be missing contact. Are the other features still operating? Auto windows up & down.. etc?
Have you checked the configuration menu? Its possible to individually disable certain functions.
Configuration Menu Structure
To enter Configuration Menu Mode: Hold the DIC 'reset' while pressing
the door panel 'unlock.' Do not do this while driving or while the key is
ON. Press ‘reset’ to exit and abort any incomplete changes.
1 - Panic! mode
2 - Display high speed
1 - clear high speed from memory
*2 - select US-style speedometer, 0-200 MPH
3 – select export-style speedometer, 0-300 km/h
3 - Activate accessory power
4 - Enter configuration menu
1 - configure windows
*1 - disable
2 - enable and calibrate windows [requires PIN]
3 - window up strength, normal [requires PIN]
4 - window up strength, strong [requires PIN]
2 - configure door locks
*1 - disable
2 - active on hand brake
3 - active on transmission in PARK
4 - active for both 2 and 3
3 - configure accessory power
1 - disable control
2 - activate power on exit
*3 - activate power on triple unlock via FOB
5 - adjust accessory power timeout
1 - 30 seconds
2 - 5 minutes
*3 - 15 minutes
4 - factory defaults (factory defaults are marked with *'s)
1 – restore to factory defaults
Ok………..here is what I did.
I pressed reset on the DIC while holding the unlock on the door panel.
Then I pressed #4 on the DIC……then I pressed #2, and again #2 on the DIC.
If this is the proper procedure it remains inoperative when setting the hand brake?
Passenger Door Unlock Assist: The Window Valet TM
can be programmed to unlock the doors to make it easy
for the passenger to exit the car. Placing an automatic
transmission in park or setting the hand brake are the
two gestures that can be selectively enabled to control
the door unlocking feature. Select one, the other, both,
or neither. Neither is the factory default.
